Re: ROCKERS ARE CLOSE!!
[Re: Moparnut426]
#644888
03/19/10 11:26 AM
03/19/10 11:26 AM
Posts: 1,178 Indy
FlyFish
Indy
What size spring and what head?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: Moparnut426]
#644892
03/19/10 01:09 PM
03/19/10 01:09 PM
Posts: 5,080 organ
maximum entropy
organ
what's your installed height? i ain't never had prollems wit harland. tall valves? what kind of heads?
[Re: Old School]
#644896
03/19/10 02:45 PM
03/19/10 02:45 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
You could try some -.050 keepers. That helped with our setup. Just remember your lowering your spring height by .050. May need to remove a shim?
that is exactly what i did with my t&d,s.
What heads you running?
[Re: cl440]
#644897
03/20/10 10:27 AM
03/20/10 10:27 AM
Posts: 4,209 New York
polyspheric
New York
X2.
Lash cap: changes the geometry. Unless it's already wrong in the opposite direction this will make things worse. Grind the rocker: and then you know exactly where it will break.
Boffin Emeritus
[Re: Moparnut426]
#644898
03/20/10 06:28 PM
03/20/10 06:28 PM
Posts: 2,864 IN
Irun5snd8th
IN
1.550 springs on mine and I definitely have to have my Harlands machined. I hate it cause the rockers dont last as long.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Leigh]
#644902
03/20/10 11:09 PM
03/20/10 11:09 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
i myself would not cut on the rocker arms.i would get the clearence another way.i would be worried that i would weaken them. with alot of spring,thats not good.....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Old School]
#644903
03/20/10 11:40 PM
03/20/10 11:40 PM
Moparnut426
Yep, My springs arent crazy heavy, but the 943 is over 540# open IIRC.
Im gonna try the keeper trick.
Kasey
[Re: Moparnut426]
#644906
03/21/10 12:04 PM
03/21/10 12:04 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
What part number is the comp .050 keepers I need. I cant find them anywhere.
kasey
630-16 is what we used. They are for 11/32, single groove valves with 10 deg retainers
