B&M Pro Stick PG shifter question #643150
03/17/10 02:58 PM
03/17/10 02:58 PM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
I was given a B&M Pro Stick that was used with a TH350. One friend of mine says you have to buy a plate to convert it to PG use. Another friend of mine says it's the same shifter. He said the plate is the same, you just 2nd and 3rd from the TH350 for 1st and 2nd(drive) for the PG.
Can anyone confirm this? I looked in Jegs for a conversion plate and couldn't find one.
Re: B&M Pro Stick PG shifter question [Re: Dart1031] #643151
03/17/10 03:05 PM
03/17/10 03:05 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: B&M Pro Stick PG shifter question [Re: HealthServices] #643152
03/17/10 03:24 PM
03/17/10 03:24 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
There defiantly diff.
Re: B&M Pro Stick PG shifter question [Re: Bob_Coomer] #643153
03/17/10 06:54 PM
03/17/10 06:54 PM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
Thanks guys!
