rebuilding stock 40 suspension questions. Spreader need #640532
03/14/10 10:15 PM
03/14/10 10:15 PM
dusterguy Offline OP
I am trying to rebuild the front suspension on my 40 Plymouth business coupe and can't seem to get it together. Do I need to spread the upper and lower control arms to install the threaded pivot points? They seem to bottom out on the tube nuts before seating on the control arms. Please help.
Re: rebuilding stock 40 suspension questions. Spreader need [Re: dusterguy] #640533
03/15/10 06:28 PM
03/15/10 06:28 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
they are a pain. I tried to keep from messing up the inner seals (looked like chunks of hose), and eventually just jammed them up and worked the shafts into the arms. There is a specfic way it all fits together, but I can't remember now. Just align all the parts and they make more sense one way....
After they are in, then screw on the pivots.
The upper arms do swivel some at the point where the pin the shock bolts to goes through. This allows the exccentric to work.
I also ran the pivots in and out of the shafts a few times to make sure they wouldn't bind.
Re: rebuilding stock 40 suspension questions. Spreader need [Re: RodStRace] #640534
03/16/10 11:20 PM
03/16/10 11:20 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
intresting topic,,i may have to take mine apart not sure yet,, to do the dropped up rights from fat man ,,and new coil springs
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
