options for front disc conversion for 65 Belvedere ?
#639835
03/14/10 02:25 PM
03/14/10 02:25 PM
Posts: 2,431 USA
SSAAHemiFan
USA
Contemplating a front disc upgrade on the 65 Belvedere I just picked up. Alot of companies are offering kits these days but it's hard to keep up with the quality of them. Has 10" drums and stops well but.. I have had a couple of panic situations already. Just a mild driver so no need for any type of racing or oversized setup. I was hoping to keep it simple (all mopar) so parts are easy to get. I'd like to retain the stock 14" rims if possible. Suggestions ? Thanks I would consider piecing together OEM stuff or buying a kit.
Re: options for front disc conversion for 65 Belvedere ?
[Re: SSAAHemiFan]
#639836
03/14/10 02:44 PM
03/14/10 02:44 PM
Posts: 415 Indiana
Pentastar440
Indiana
I have '79 Cordoba discs on my '65 and they work great. Any mid-late 80s 5th Avenue-Diplomat also work. The Cordobas have larger rotors (heavier)than the Diplomat brakes. Either should work fine. Find a donor car and get everything between the upper and lower ball joints and bolt it together. While doing the conversion replace everything you can with new stuff like calipers,hoses etc.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
[Re: Pentastar440]
#639838
03/14/10 02:47 PM
03/14/10 02:47 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Didn't think the larger rotor would allow the use of the 14" rims.
[Re: SSAAHemiFan]
#639839
03/14/10 02:56 PM
03/14/10 02:56 PM
Posts: 415 Indiana
Pentastar440
Indiana
You will also need to upgrade to a dual master cylinder. I got mine from Mancini (DrDiff and others on here have them too) and I don't have a proportioning valve, mine works fine without one. I would get everything installed without a proportioning valve and see how it works. If you don't have any premature wheel lockup you won't need one.
[Re: Andrewh]
#639846
03/15/10 12:42 AM
03/15/10 12:42 AM
Posts: 119 Washington state
pinkmeepmeep
Washington state
I have a 65 belvedere that I put disk brakes using newer A body stuff cuz I couldn't find the cordoba caliper brackets. Changed to an a body manual disc master cylinder but there are different bore sizes and I used the larger bore. next time I replace the master cylinder I am going to try the smaller bore cylinder because I have heard that although you have to move the pedal farther to displace the same amount of fluid, pedal pressure is lighter. Don't get me wrong my brakes work great, but it would be nice to have a little softer pedal.
