dana 60 carriers #638772
03/13/10 12:20 PM
03/13/10 12:20 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
does the carrier change once you get past a certaian ring size,say goin from high 4,s to mid 5 ratios ?
Re: dana 60 carriers [Re: bonefish] #638773
03/13/10 01:14 PM
03/13/10 01:14 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
yes, I don't remember the numbers but there are two different carriers
Re: dana 60 carriers [Re: bonefish] #638774
03/13/10 02:06 PM
03/13/10 02:06 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Usually deeper than 4.10, you need a different carrier. However there have been some special gearsets made that can make it a grey area.
Sheldon
Re: dana 60 carriers [Re: RUNCHARGER] #638775
03/13/10 02:09 PM
03/13/10 02:09 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
4.10 is usually the split 3.54-4.10 use one carrier, 4.56 up use another.
There are some 4.30, thick ring gear sets, for use on a 4.10 down carrier.
Re: dana 60 carriers [Re: RobX4406] #638776
03/13/10 04:35 PM
03/13/10 04:35 PM
Cab_Burge Online work
Cab_Burge  Online Work
Strange Engr. sells a 4:30 gear set that fits on the 3:54 to 4:10 carrier
