Hub-centric wheel spacers
#63843
05/26/08 12:30 PM
05/26/08 12:30 PM
Posts: 733 Nampa, ID
MadMatt
Nampa, ID
I'm thinking about having a set of spacers made to make my aluminum Halibrand wheels hub-centric instead of lug-centric. I was wondering if any of you out there have done something similar and how it worked out. Did you make the spacers out of aluminum or steel? Did you go for an interference fit in the wheel, or are they free floating? About how much did it cost you to have them made? Any info, input, or photos are much appreciated!
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Hub-centric wheel spacers
[Re: MadMatt]
#63845
05/26/08 12:54 PM
05/26/08 12:54 PM
Posts: 4,749 Florida
BDW
I'm curious why you would want hub over lug centric?
[Re: patrick]
#63853
05/26/08 03:10 PM
05/26/08 03:10 PM
Posts: 27,477 So Cal
autoxcuda
So Cal
...I don't thing the magnum 500's were hub centric, either.
Correct, Magnum 500 are not hub centric. That why is so hard to find original rims that don't have their lug tapers all wallowed out. My alignment guy like to wheel balance those rims on the car also, since they don't center right on a wheel balancing machine.
Now Magnum's are steel rims. Aluminum rims with tapered lug seating are going to wear faster. I've seen many factory aluminum rims with tapered steel lug seat inserts. Nice feature and I bet it's not by accident.
