Does a original R block reguire a goofy rear main seal? #637283
03/12/10 01:36 AM
03/12/10 01:36 AM
IN
Irun5snd8th Offline OP
IN
I got an original R block and I have always had to grind the rear main seal some as the ends always protrude over the surface. Could this be the result of a honing operation on the main journals or something like that? Its almost like one of the mating surfaces on the block or main cap has been ground?
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Does a original R block reguire a goofy rear main seal? [Re: Irun5snd8th] #637284
03/12/10 09:21 AM
03/12/10 09:21 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
The R block takes the same rear main seal as the 273-340 LA engines.
If the rear seal is flush with the pan rail on one side, it should protrude approx. .010-.020" on the other. Measurements should be taken off the main body of the seal and not the seal lip as they have a chamfer on one side of the sealing lip to fit the other half.
You should have identical measurements with the main cap and the block.
Greg
Re: Does a original R block reguire a goofy rear main seal? [Re: roadhazard] #637285
03/12/10 10:57 AM
03/12/10 10:57 AM
IN
IN
I will check it again and see just how far out the ends are poking. I think it is more than .020 but I will double check. It does seem like alot. Perhaps I can post a pic later today?
Re: Does a original R block reguire a goofy rear main seal? [Re: Irun5snd8th] #637286
03/12/10 01:26 PM
03/12/10 01:26 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Pics are worth a thousand words
