Re: Horn relay
[Re: 70duster340]
#637109
03/12/10 12:44 AM
03/12/10 12:44 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
I think one the ebay ones I gave you by the email will be definitelly the best option.
If I found the way to ship it cheap up to you the NOS one I have, will let you know
Re: Horn relay
[Re: shadetree72]
#637117
03/12/10 11:38 PM
03/12/10 11:38 PM
NachoRT74
Valencia, España
I searched "relays" in general and started looking at all that were listed until I found the one that looked like what I had. It worked as far as a horn relay, but I don't know about the key buzzer as mine didn't work when I got the car-72 Challenger. My relay plugs directly into the fuse box, I'm not sure what your setup is. Good luck, hope this helps.
71/73 and lates E and B bodies uses same configuration and everything than A bodies BUT the bracket attached to cover. If Somebody is not able to find the one with brackes and get one without the brackes and STIL HAVE the old piece, you can remove the covers and interchange, fitting the new piece into the old piece cover with the bracket... voila!
It's alive!!
[Re: NachoRT74]
#637118
06/06/10 11:50 AM
06/06/10 11:50 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
I can't speak for the Echlin part but it cross references with BDW part R218 available at Advance Auto. I found this thread trying to track down a horn relay for my 71 Challenger.
It is a very close match to the original relay and DOES include the key in buzzer.
The relay fits in my fuse box and works with no modifications. But there are 2 slight differences which could easily be fixed to make it a closer match. The bracket, on the BWD part at least, is held on with what looks like 3 small peened over mounting studs, which could be easily ground off. And three of the blades (the three in a group on one side) have slight steps at the base making them a tad too wide for it to fit in the fuse box flush, again easily fixed with a dremel.
But again the part fits (mostly) and works in my 71 Challenger as is. Thanks for this thread it helped get my horns going again after 9 years, since some jackass at a shop removed mine to kill the key in buzzer, and then proceeded to loose it.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
