early A 273 ex manifolds wont seal Help! #63598
05/26/08 01:49 AM
05/26/08 01:49 AM
RapidRobert Offline OP
'65 dart drivers side 273 ex manifold on a 83 318. leaks out the bottom side on the manifold on cyl 5 & 7. I know the contact area is thin so should I ride the gasket high as it will go & WHICH gasket should I use?? thank you for your time. this will be my 4th time on this,I want this to be it PS I did plug the air injection holes.
Re: early A 273 ex manifolds wont seal Help! [Re: RapidRobert] #63599
05/26/08 06:29 AM
05/26/08 06:29 AM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
You have to grind some of the block away. The manifold is making contact with the block. I've done this conversion several times (318 to early A-body).
I have a 84 318 in the garage that I just took out of a 66 Dart with 273 manifolds if you need a pic
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: early A 273 ex manifolds wont seal Help! [Re: RapidRobert] #63600
05/26/08 08:51 AM
05/26/08 08:51 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
What you need to grind away is part of the cylinder head where the air injection port is. I've been there, had to do it. Drop the exhaust pipe, take the manifold off and take the gasket off, then lay the manifold back up against the head. Just behind the steering column, you'll see the portion of the manifold that drops down and curves in towards the block hit the head.
Then there is the joy of reaching it with a grinder.
Good luck!
Jim Burch
Re: early A 273 ex manifolds wont seal Help! [Re: JBurch] #63601
05/26/08 09:35 AM
05/26/08 09:35 AM
Thanks guys & yes please a pic will help guide me on this.
Re: early A 273 ex manifolds wont seal Help! [Re: RapidRobert] #63602
05/26/08 04:13 PM
05/26/08 04:13 PM
Stuart, FL
Grassosgarage Offline
Stuart, FL
'70 Cuda 440/auto
'70 Duster 340/4sp project
'70 Satellite convert 318 survivor
