56 Dodge Pickup parts #634752
03/09/10 10:55 AM
03/09/10 10:55 AM
Minnesota
72blubird Offline OP
Minnesota
Anyone know of any exterior part suppliers for 56 1/2 ton pickups. Looking for rear fenders, box etc. Also for front end suspension what it is reccommended? Will/does have a 400/727/8.75 in it.
What was I thinking....
Re: 56 Dodge Pickup parts [Re: 72blubird] #634753
03/09/10 04:40 PM
03/09/10 04:40 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
If i remember right, any of the step beds thru 85 will work. My 57 had a step, long bed but i shortened it to a short bed.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 56 Dodge Pickup parts [Re: rattler] #634754
03/09/10 09:46 PM
03/09/10 09:46 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yep, rear fenders fit from 53 through the end of step side trucks in the mid 80s, there was an optional left rear fender with a cut out for mounting a spair on the box side. The top rail went from a 45 degree angle to 90 degrees in 57. After 57, a step side box was either a 7 1/2' or a 9' box, but all were the same except the length.
Dodge trucks used the beam axle through 71 model year with a big block option from about 67 or 68 on, The newer upgraded drum brakes bolt on to your axle. If you want disc brakes, I think www.rustyhope.com makes a kit to convert to discs. A lot of guys are clipping the 50s trucks with Dakota clips, and some are using the entire Dakota frame. Saying what is best depends on what you want. Gene
