Page 1 of 3 1 2 3
Another Eagle cast crank broken (408 stroker) #634657
03/09/10 07:30 AM
03/09/10 07:30 AM
Buenos Aires, ARGENTINA
madmax2 Offline OP
madmax2  Offline OP
Stroker 408, Eagle cast crank, 360 mains... 450-470 hp (no more)... 4 speed manual and Sumitomo street radial tires (never slick).
It broke in a light burnout, 1500 miles only.
Do you have any idea of the cause?
This crank suck... we will buy a 4340 Ohio crank... no more Eagle cranks...
'70 Dodge GTX sb 418ci (Early A-body),
Lunati Solid cam 270°/243°@.050/.548", Edelbrock Heads, Weiand X-CELerator,
Holley Terminator EFI, Tremec 6 sp manual, 3.90:1, TTI Headers.
Re: Another Eagle cast crank broken (408 stroker) [Re: madmax2] #634658
03/09/10 10:07 AM
03/09/10 10:07 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Thats the second one i saw that broke the snout. After examining the one I had, I thought the weak point was the rear arm/journal cross section especially with all 8 cylinders twisting it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Another Eagle cast crank broken (408 stroker) [Re: madmax2] #634659
03/09/10 10:11 AM
03/09/10 10:11 AM
that's not unusual with a cast crank. they just aren't made to hold up to that much horsepower.
Re: Another Eagle cast crank broken (408 stroker) #634660
03/09/10 10:42 AM
03/09/10 10:42 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if it were me, i wouldn't race a manual trans behind a cast crank. some folks may get by with it but my luck wouldn't.
Re: Another Eagle cast crank broken (408 stroker) [Re: lewtot184] #634661
03/09/10 11:57 AM
03/09/10 11:57 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have seen an aweful lot of those eagle cranks break just like that on the front end.
Funny how SCAT cast cranks don't seem to be doing that
Re: Another Eagle cast crank broken (408 stroker) [Re: HotRodDave] #634662
03/09/10 12:19 PM
03/09/10 12:19 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I have a friend that races a Nova (yuck) with a 383 with a Scat cast crank with a jerico 4spd. 508hp to the wheels and no breakage and its been together 2 years. I've seen numerous eagle rods fail in weird ways with no rime or reason...
Re: Another Eagle cast crank broken (408 stroker) [Re: SLOW67] #634663
03/09/10 12:32 PM
03/09/10 12:32 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Dram,tell me something new.Why does a stock 360 crank hold 450 hp and not this cast crank?I have never a stock crank breaking but I could be wrong.back to the topic I had one of the cast when they first came out and my block let go before the crank did.After twisting 2 h-beams the crank was still good.i was running 10.50@3400 pound car.if I was building a few motor I would do the steel crank.
Re: Another Eagle cast crank broken (408 stroker) #634664
03/09/10 12:41 PM
03/09/10 12:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s what I used to think too Dan till I saw Darrell Parks click off consistent low 9`s with his cast crank iron headed small block. Granted it`s a 2500 lb. car but I`m guessing he`s making more power than the poster.
Re: Another Eagle cast crank broken (408 stroker) [Re: Thumperdart] #634665
03/09/10 01:14 PM
03/09/10 01:14 PM
madmax2 Offline OP
madmax2  Offline OP
I not find reason why the eagle cast cranks (mopar , chevy, etc) are broken in the same place.
The car are a 3550 lb A-body.
Re: Another Eagle cast crank broken (408 stroker) [Re: madmax2] #634666
03/09/10 01:28 PM
03/09/10 01:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
That place does not have a lot of material, it is light right there to help with balancing. The eagle cranks I have seen break often have air bubbles in the casting. The air bubbles mean it is weak and it is light weight over all so they have to take even more weight off somewhere on the side where the throw is to lighten it enough to balance. It all adds up to a really flimsey crank.
Re: Another Eagle cast crank broken (408 stroker) [Re: madmax2] #634667
03/09/10 01:34 PM
03/09/10 01:34 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Its hard to tell from pics but it looks like there was a crack long before failure, shiny part in the brake, what balancer were you running?
Re: Another Eagle cast crank broken (408 stroker) [Re: emarine01] #634668
03/09/10 01:52 PM
03/09/10 01:52 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Internal balance or external? As was asked.. what balancer and how did it go on?
Re: Another Eagle cast crank broken (408 stroker) [Re: moper] #634669
03/09/10 02:00 PM
03/09/10 02:00 PM
madmax2 Offline OP
madmax2  Offline OP
is the engine of a buddy, the damper it's a Mopar Performance.
Re: Another Eagle cast crank broken (408 stroker) [Re: madmax2] #634670
03/09/10 02:06 PM
03/09/10 02:06 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Just me tossing out ideas here... This isnt the first I've seen in terms of web stuff of that particular break. I have a couple of these in service in the 460-480 level (and automatics) and I will admit I'm nervous enough to probably stop sourcing them. But it terms of the "whys"... It looks like it started at the fillet which "should" be a fairly strong area. But that's where the otrsional stress is and the rpm doesnt matter if the harmonis are bad for wahtever reason. External balancing lends itself to stressing the crank more forcing it to flex, and a loose balancer or one that was hammered on or honed to fit more loosely can all contribute to crank stress, as can detonation. Never mind the 4sp part.
Re: Another Eagle cast crank broken (408 stroker) [Re: moper] #634671
03/09/10 02:27 PM
03/09/10 02:27 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Another question comes to mind, Were there any oiling system mods to this build or bone stock?
Re: Another Eagle cast crank broken (408 stroker) [Re: Otherlane] #634672
03/09/10 02:33 PM
03/09/10 02:33 PM
Dram,tell me something new.Why does a stock 360 crank hold 450 hp and not this cast crank?I have never a stock crank breaking but I could be wrong.back to the topic I had one of the cast when they first came out and my block let go before the crank did.After twisting 2 h-beams the crank was still good.i was running [Email]10.50@3400[/Email] pound car.if I was building a few motor I would do the steel crank.
i don't have a definitive answer for you. i've seen plenty of broken cast cranks over my 34+ years in this business. there are a lot of places the blame could be placed, so take your pic.
bad cranks/ castings
bad balance job, internal vs. external
bad damper
heavy bobweights
and the list goes on and on.
some cranks seem to survive, others don't.
i do recommend moving up to a forged crank when your plans exceed 450 hp. that 450 hp might be fine, but what happens when you start making other improvements and then your at 500, or 550 or even more. plan ahead. it's cheaper in the long run to buy the better crankshaft up front IMO unless it's just going to be a slightly warmed over stock type build. i understand about working within a budget, but you don't ask for temporary fillings (i.e. cheaper) when you go to the dentist, so don't ask for a temporary crankshaft when you build your bracket motor.
Re: Another Eagle cast crank broken (408 stroker) #634673
03/09/10 02:37 PM
03/09/10 02:37 PM
PA
moparacer Offline
moparacer  Offline
PA
Exact same failure I had except mine broke at the back.
Just too thin between the rod and main journals.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Another Eagle cast crank broken (408 stroker) [Re: Otherlane] #634674
03/09/10 08:38 PM
03/09/10 08:38 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
Because old stock cranks was not made in China!
Re: Another Eagle cast crank broken (408 stroker) [Re: dart_73_br] #634675
03/09/10 08:38 PM
03/09/10 08:38 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
Because old stock cranks were not made in China!
1973 Brasilian Dart
E100, boosted 390"
Re: Another Eagle cast crank broken (408 stroker) [Re: dart_73_br] #634676
03/09/10 08:52 PM
03/09/10 08:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
JMO but I would believe that it was a balance issue,
got it balanced from the company and in a lot of cases
thats not even close.... again JMO without knowing facts
Page 1 of 3 1 2 3
