Another Eagle cast crank broken (408 stroker)
#634657
03/09/10 07:30 AM
03/09/10 07:30 AM
Posts: 143 Buenos Aires, ARGENTINA
madmax2
'70 Dodge GTX sb 418ci (Early A-body), Lunati Solid cam 270°/243°@.050/.548", Edelbrock Heads, Weiand X-CELerator, Holley Terminator EFI, Tremec 6 sp manual, 3.90:1, TTI Headers.
Re: Another Eagle cast crank broken (408 stroker)
[Re: madmax2]
#634658
03/09/10 10:07 AM
03/09/10 10:07 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Thats the second one i saw that broke the snout. After examining the one I had, I thought the weak point was the rear arm/journal cross section especially with all 8 cylinders twisting it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: madmax2]
#634659
03/09/10 10:11 AM
03/09/10 10:11 AM
that's not unusual with a cast crank. they just aren't made to hold up to that much horsepower.
[Re: lewtot184]
#634661
03/09/10 11:57 AM
03/09/10 11:57 AM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have seen an aweful lot of those eagle cranks break just like that on the front end. Funny how SCAT cast cranks don't seem to be doing that
[Re: SLOW67]
#634663
03/09/10 12:32 PM
03/09/10 12:32 PM
Posts: 830 east coast
Otherlane
east coast
Dram,tell me something new.Why does a stock 360 crank hold 450 hp and not this cast crank?I have never a stock crank breaking but I could be wrong.back to the topic I had one of the cast when they first came out and my block let go before the crank did.After twisting 2 h-beams the crank was still good.i was running 10.50@3400 pound car.if I was building a few motor I would do the steel crank.
[Re: Thumperdart]
#634665
03/09/10 01:14 PM
03/09/10 01:14 PM
madmax2
I not find reason why the eagle cast cranks (mopar , chevy, etc) are broken in the same place. The car are a 3550 lb A-body.
[Re: madmax2]
#634666
03/09/10 01:28 PM
03/09/10 01:28 PM
HotRodDave
Kalispell Mt.
That place does not have a lot of material, it is light right there to help with balancing. The eagle cranks I have seen break often have air bubbles in the casting. The air bubbles mean it is weak and it is light weight over all so they have to take even more weight off somewhere on the side where the throw is to lighten it enough to balance. It all adds up to a really flimsey crank.
[Re: emarine01]
#634668
03/09/10 01:52 PM
03/09/10 01:52 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Internal balance or external? As was asked.. what balancer and how did it go on?
[Re: moper]
#634669
03/09/10 02:00 PM
03/09/10 02:00 PM
madmax2
is the engine of a buddy, the damper it's a Mopar Performance.
[Re: madmax2]
#634670
03/09/10 02:06 PM
03/09/10 02:06 PM
moper
Columbia, CT
Just me tossing out ideas here... This isnt the first I've seen in terms of web stuff of that particular break. I have a couple of these in service in the 460-480 level (and automatics) and I will admit I'm nervous enough to probably stop sourcing them. But it terms of the "whys"... It looks like it started at the fillet which "should" be a fairly strong area. But that's where the otrsional stress is and the rpm doesnt matter if the harmonis are bad for wahtever reason. External balancing lends itself to stressing the crank more forcing it to flex, and a loose balancer or one that was hammered on or honed to fit more loosely can all contribute to crank stress, as can detonation. Never mind the 4sp part.
[Re: Otherlane]
#634672
03/09/10 02:33 PM
03/09/10 02:33 PM
Dram,tell me something new.Why does a stock 360 crank hold 450 hp and not this cast crank?I have never a stock crank breaking but I could be wrong.back to the topic I had one of the cast when they first came out and my block let go before the crank did.After twisting 2 h-beams the crank was still good.i was running [Email]10.50@3400[/Email] pound car.if I was building a few motor I would do the steel crank.
i don't have a definitive answer for you. i've seen plenty of broken cast cranks over my 34+ years in this business. there are a lot of places the blame could be placed, so take your pic. bad cranks/ castings bad balance job, internal vs. external bad damper heavy bobweights and the list goes on and on. some cranks seem to survive, others don't. i do recommend moving up to a forged crank when your plans exceed 450 hp. that 450 hp might be fine, but what happens when you start making other improvements and then your at 500, or 550 or even more. plan ahead. it's cheaper in the long run to buy the better crankshaft up front IMO unless it's just going to be a slightly warmed over stock type build. i understand about working within a budget, but you don't ask for temporary fillings (i.e. cheaper) when you go to the dentist, so don't ask for a temporary crankshaft when you build your bracket motor.
#634673
03/09/10 02:37 PM
03/09/10 02:37 PM
Posts: 2,521 PA
moparacer
PA
Exact same failure I had except mine broke at the back.
Just too thin between the rod and main journals.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Otherlane]
#634674
03/09/10 08:38 PM
03/09/10 08:38 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Because old stock cranks was not made in China!
[Re: dart_73_br]
#634676
03/09/10 08:52 PM
03/09/10 08:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
JMO but I would believe that it was a balance issue, got it balanced from the company and in a lot of cases thats not even close.... again JMO without knowing facts
