Will 295/50-15 on 15x10 fit on 70 Cuda? #634253
03/08/10 05:28 PM
03/08/10 05:28 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Hi guys, I'd like to install 295/50-15 in the rear of my AAR, wondering if anyone ever tried fitting this size on a 70 up Cuda? I have no idea what backspacing would be necessary, and I'd rather not have to move my leafs in. Thanks for any input!
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: kielbasa] #634254
03/08/10 06:33 PM
03/08/10 06:33 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
then your answer is no least not without air shocks
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: kielbasa] #634255
03/08/10 06:36 PM
03/08/10 06:36 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
This is how I measure for backspace -
Make or buy a plumb bob. Drop a line from the inside of the wheel house on whatever the tire will rub on first. Usually it's the leaf spring. Don't forget to correct for wheel travel if there is anything the tire will rub when the suspension is compressed. Make your first mark on the floor where the plumb bob lands.
Now drop a line from the surface the rim seats to. Brake drum, rotor, whatever. Mark a line on the floor parallel to the first mark.
Now drop a line from the outer wheelhouse correcting for anything that the tire will rub when the suspension is compressed. Make your third mark on the floor parallel to the first two marks.
The outer marks are the maximum section width tire you can stuff in there. Section widths of the tires is usually posted on the tire mfg's website. Subtract 1" from the section width to allow for 1/2" clearance on the inner and outer edges of the tires.
For backspace measure from the center mark to both outer marks and subtract the smaller number from the larger. That number is your backspace positive or negative depending on which way the wheel needs to shift to be in the center of the wheel well.
Do the same on the front and account for the turning of the wheels. I mock up a cardboard wheel and attach it to the wheel mating surface. Use a ruler during lock to lock turning to see what will fit in the front.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: kielbasa] #634256
03/08/10 08:04 PM
03/08/10 08:04 PM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Here's my 72, not a great pic, it is tight, and I narrowed the rear end
I forbid my content here from being learned and used by artificial intelligence systems.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: jcc] #634257
03/08/10 09:14 PM
03/08/10 09:14 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
wow, that's what I was thinking - Torque Thrusts - looks tough! I just worry about 50 series being too short and not filling the wheel well.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: kielbasa] #634258
03/09/10 10:15 AM
03/09/10 10:15 AM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Sorry I should have mentioned, that is a 295/50/15 on a 10" TT in my pic.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: jcc] #634259
03/09/10 11:43 AM
03/09/10 11:43 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
4.5" rearspace with a 295 will clear the leafs but will most likely put the outer side of tire even with the wheel lip. In my past running N-50s on a 10" wide wheel I needed airshocks to keep from hitting the tire on the bumps.
Keep old mopars alive.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: 2boltmain] #634260
03/09/10 12:16 PM
03/09/10 12:16 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
295 50 50 tires do fit with 4.5" back spacing.
Here are some pictures using 15 x 8 rims.
My goal was to fit the biggest tire in a stock wheel well. It does fit! BUT, if I added a second person in my car, the passenger tire rubbed on the quarter panel. Even when it was just me driving and I hit a bump and it excersized the suspension, the tire on the pass side would rub - bad.
One day I, I tried to drive two additional people. No - way. I had to drive home and change cars to drive the other people.
#1
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: cudaized] #634261
03/09/10 12:17 PM
03/09/10 12:17 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
I measured that a 12" wide tire would fit. Depending on your suspenson travel.
#2
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: cudaized] #634262
03/09/10 12:18 PM
03/09/10 12:18 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
#3
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: cudaized] #634263
03/09/10 12:19 PM
03/09/10 12:19 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
#4
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: cudaized] #634264
03/09/10 12:20 PM
03/09/10 12:20 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
#5
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: cudaized] #634265
03/09/10 12:31 PM
03/09/10 12:31 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
It got to the point that I did not want to drive wth the 295 50 15 tires anymore.
I switched back to 275 50 15 for more than one reason, though.
I need traction. The standard street tires would not grip on dry roads.
So back to the "Sticky" soft tires.......
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: cudaized] #634266
03/09/10 01:05 PM
03/09/10 01:05 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Thanks! Good info......
Yes, I am also considering 275's (60 series though)...personally I like the wide tire look and am afraid the 275's would look a little skinny...
I would consider raising the rear of the car, but also am afraid if it will adversely affect handling.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: kielbasa] #634267
03/09/10 01:25 PM
03/09/10 01:25 PM
NY usa
540challenger Offline
NY usa
I am running 275/50 on my challenger and when i compared them to my buddy who is running 275/60 "same brand and type tire" The difference is night and day how wider my tire is.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: kielbasa] #634268
03/09/10 04:19 PM
03/09/10 04:19 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
I still have those Cooper Cobra 295 50 15 tires that I took off. Just sitting around, almost new. If you are interest in purchasing....
cudaized@cudaized.com for more pictures.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: 540challenger] #634269
03/09/10 05:30 PM
03/09/10 05:30 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
I thought 275 is 275mm in cross section, regardless of the aspect ratio.....I'll have to look at a 275/50 vs a 275/60 sometime......
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: kielbasa] #634270
03/09/10 07:28 PM
03/09/10 07:28 PM
NJ
440challenger Offline
NJ
275 50 is much wider then a 275 60. had 275 50s on my challenger and they looked awesome.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: 440challenger] #634271
03/09/10 08:58 PM
03/09/10 08:58 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
if a 50 series tire is wider than a 60 series (given the same section width), this goes against what I have learned about tire sizing....please elaborate.
Re: Will 295/50-15 on 15x10 fit on 70 Cuda? [Re: kielbasa] #634272
03/09/10 09:06 PM
03/09/10 09:06 PM
manitoba canada
BleedDodge Offline
BleedDodge  Offline
manitoba canada
A 275/50 shouldn't be wider than a 275/60, just shorter.
