Adding relays to your headlamps electrical? #634224
03/08/10 05:59 PM
03/08/10 05:59 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
The mad eletrical kit comes with a fusable link. Can that fusable link be replaced with a breaker? If so what amp breaker would u use with a 30 amp relay? Is there a rule to go by for what amp breaker u use?
Re: Adding relays to your headlamps electrical? [Re: RATTRAP] #634225
03/08/10 06:38 PM
03/08/10 06:38 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Depends on the watt of lamps and wire size. I think 30 would be a bit to big. if you have (2) 60 watt bulbs, them thats 10 amps so I would suggest a 15amp breaker, but I dont know what wattage the lamp is
