Re: Innovate LM-1 opinions
[Re: joshking440]
#633919
03/08/10 10:57 AM
03/08/10 10:57 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
Ive got one..and am interested in knowing the proper range/readings for E85... and is there any hardware differences needed.? from fuel to E85 or alcohol.? good post Josh
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: joshking440]
#633923
03/08/10 01:07 PM
03/08/10 01:07 PM
Posts: 2,526 PA
moparacer
PA
I bought a LM-2 the other week and am wishing I would have bought the LM-1 now.
The LM-1 is a good unit but the LM-2 is riddled with problems I am finding out.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: joshking440]
#633924
03/08/10 05:24 PM
03/08/10 05:24 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
here is a bump for ya.i got the same deal for 200$ i just have not used it yet.
[Re: blownzoom440]
#633925
03/08/10 05:38 PM
03/08/10 05:38 PM
Posts: 2,526 PA
moparacer
PA
Where you guys getting the deal on the LM-1's?
[Re: joshking440]
#633927
03/08/10 05:49 PM
03/08/10 05:49 PM
Posts: 757 Reading PA
duster400
Reading PA
I know that there are no hardware differences between them, just what conversion you use. my understanding is that it reads in lambada, and we tell it what to convert to. I think, but I not certain that we can simply use lambada, and not use a conversion if we want
You can convert Lambda to A/F in the software. Or you can use lambda. The conversion to A/F from Lambda is. Lambda x Stoich I believe Stoich for E85 is somewhere around 9.7:1.
Anthony
[Re: joshking440]
#633928
03/08/10 06:05 PM
03/08/10 06:05 PM
Posts: 3,441 Mo.
supercomp
Mo.
Well I hope it works cause I just bought it from the guy. I think $200 for the lm1 and the lma-2 rpm kit all brand new is a pretty good deal...I hope some others chime in with tips and tricks for the unit
We had to move the sensors from the collectors to 18 in. from the ex. port to get a consistant reading. Dragster on alky carb.
