71 RR Eddy RPM Intake Clearance with Fact Dual Snorkle #63367
05/25/08 06:11 PM
05/25/08 06:11 PM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
Does anyone use a RPM intake (383-400 engine) in a 71-72 Roadrunner with the factory dual snorkel air cleaner? If so how close is the air cleaner to the 71-72 Roadrunner Non-Airgrabber Hood?
Thanks,
Ron
Re: 71 RR Eddy RPM Intake Clearance with Fact Dual Snorkle [Re: Ronnman] #63368
05/26/08 10:14 AM
05/26/08 10:14 AM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
BTT
Re: 71 RR Eddy RPM Intake Clearance with Fact Dual Snorkle [Re: Ronnman] #63369
05/26/08 10:43 AM
05/26/08 10:43 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
I don't think it will fit. I believe the RPM is 1.75" taller than stock. How much clearance do you have now?
Re: 71 RR Eddy RPM Intake Clearance with Fact Dual Snorkle [Re: sixpack4spd] #63370
05/26/08 11:38 AM
05/26/08 11:38 AM
North Dakota
440abody Offline
440abody  Offline
North Dakota
The fix is pretty easy. I had to do this on my 73 dart with a 440. Get a cheap drop base air cleaner and then cut the bottom out of your factory dual snorkel. Weld it all up, finish it off and no one can tell the difference. I ended up using a 1" drop to clear my hood, and my best freind just had to do the same thing to his 70 cuda with a 440. I think he used a 3/4" drop to get it to clear.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: 71 RR Eddy RPM Intake Clearance with Fact Dual Snorkle [Re: 440abody] #63371
05/26/08 12:10 PM
05/26/08 12:10 PM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
Thanks for the replies. I think I have about 1-1/2" clearance, but I have not measured it. I wanted to see if anyone had experience with the OEM dual snorkle air cleaner. Sounds like I will have to modified the air cleaner if I go with the RPM.
440abody - What drop base cleaner did you use to have the same diameter air filter?
Ron
Re: 71 RR Eddy RPM Intake Clearance with Fact Dual Snorkle [Re: Ronnman] #63372
05/26/08 12:28 PM
05/26/08 12:28 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
You don't even have to cut your original base. (I wouldn't do that) If you want it to seal, buy a single snorkel (their cheap) & use that base, or... just put the drop base on it, then put snorkel top over the air filter. It'll be open around the bottom, but you can't see it. May even help breath a little better.
Re: 71 RR Eddy RPM Intake Clearance with Fact Dual Snorkle [Re: StealthWedge67] #63373
05/26/08 01:15 PM
05/26/08 01:15 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
The newer style air cleaners are not like the one's from the sixties. They have the snorkles in the base and and the lid is separate. Even the singles of the seventies are the same. As far as cutting the base, it's simple, I first trimmed the drop base to fit inside the where the factory one has a slight ridge and then cut it along that ridge. Welded in the drop finished the welds off by grinding and using a bit of filler. Sanded, primed with high build primer, sanded again, painted it. By the way I saved the piece I cut out just in case I might ever want to put it back.
Re: 71 RR Eddy RPM Intake Clearance with Fact Dual Snorkle [Re: 440abody] #63374
05/26/08 01:23 PM
05/26/08 01:23 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
Ronnman I sent you a PM.
Re: 71 RR Eddy RPM Intake Clearance with Fact Dual Snorkle [Re: 440abody] #63375
05/26/08 02:36 PM
05/26/08 02:36 PM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
Thanks,
Ron
