5.7 Hemi block limits? #633402
03/07/10 10:18 PM
03/07/10 10:18 PM
Gainesville, Fl
lildevil1972 Offline OP
Gainesville, Fl
Hey guys i was wondering if anybody knows what the horsepower limits on a 5.7 hemi block are. I picked up a 5.7 cheap and am dreamin of my next build being a twin turbo 392 hemi. It seems pretty beefy with cross bolted main caps and i have seen some at 1000 horse but how reliable is that? It would have all good forged internals, arp main studs and maybe a short fill of hard block?
Re: 5.7 Hemi block limits? [Re: lildevil1972] #633403
03/07/10 11:42 PM
03/07/10 11:42 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Must not have any 5.7 builders out tonight.
Re: 5.7 Hemi block limits? [Re: lildevil1972] #633404
03/07/10 11:59 PM
03/07/10 11:59 PM
MN
hemidup Offline
hemidup  Offline
MN
With your high HP goals, I'd stick with the stock 3.58" stroke. Going with a 4.05" stroke and that much HP puts too much strain on the thrust sides. At a 1000 HP, unfilled blocks have had a tendancy to crack the cylinder walls. Looks like the cracks usually start at the bottom of the cylinder on the thrust side and works its way towards the top. Some of the cracks that I've seen haven't gone completely to the top of the cylinder, stopping short about a 1/2" down. I have a partial filled block here that'll get about 1300 horses thrown at it. I guess we'll see soon enough is filling the block is enough.
Edit: These were 4.05" and 4.08" stroked 6.1 blocks. Also the 5.7 has a stronger main web design than the 6.1.
Jerry Williams.
