Re: 64 Max Wedge choke questions
[Re: screamindriver]
#633223
03/12/10 11:39 PM
03/12/10 11:39 PM
Here's the engine shot and what I'm starting with...
your heater hoses need to be rerouted away from the throttle linkage, you need those lines to go over drivers side fender. norm brady has the correct heater hoses.with the correct bends.
#633225
03/13/10 11:03 AM
03/13/10 11:03 AM
Posts: 1,178 MN
ryangtogtx
MN
#633226
03/13/10 11:31 AM
03/13/10 11:31 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
There's no stamping on the carb base that I can see on either one...I don't know much about the carb tags but these don't look like the usual carb tags I've seen...
Being that the base's are not stamped and the tag dates plus the SA,I would think they are over the counter replacements.
[Re: 62maxwgn]
#633227
03/13/10 11:50 AM
03/13/10 11:50 AM
Posts: 5,160 Texas
dannysbee
Texas
The carbs that are not stamped are factory installed carbs and the carbs that are marked on the base are over the counter. I was was under the impression that the tags with a bead around the edge and the three hash marks at the bottom of the tag were correct. Thanks for the great pictures.
Getting old just means you were smarter than some and luckier than others.
