Re: Educate me: Offset Shackles
[Re: Got2Gnow]
#630476
03/05/10 05:06 PM
03/05/10 05:06 PM
DaytonaTurbo
Manitoba, Canada
Dr. Diff sells these kits, hopefully he will chime in, here's right off his website: Quote:
DoctorDiff E-body 1″ offset spring hanger/shackle kit for standard springs. Can be used to bolt B-body rearend into E-body with no modifications $175
DoctorDiff E-body 1″ offset spring hanger/shackle kit for Superstock springs. Can be used to bolt B-body rearend into E-body with no modifications $185
DoctorDiff ‘71-’74 B-body 1 1/4″ offset spring hanger/shackle kit for standard springs $185
The way I understand it, the 1" offset kits allow you to use your stock rear leaf spring perches and offset designed front spring hangers. The 3" kits require you to cut a notch in the frame and weld the new front spring hangers in there, as well as relocating the rear shackles into the frame rail, eliminating the rear leaf spring perches. I think both kits require you to move the axle tube perches, unless he sells a spacer plate for the 1" kit...? I the 3" kit I know requires moving the axle tube perches.
[Re: DaytonaTurbo]
#630483
03/06/10 01:17 AM
03/06/10 01:17 AM
340dart4spd
Parts Problem
Parts Problem
Is it safe to weld the perches onto the axle without disassembling the axle, removing the axle shafts, etc?
Opinions will differ..
[Re: DaytonaTurbo]
#630484
03/06/10 10:08 AM
03/06/10 10:08 AM
Posts: 5,634 Detroit area
6PAX
Detroit area
Mine was just recently done without disassembly and there were no problems.
