Re: 318 rockers?????
[Re: MoparforLife]
#629882
03/04/10 02:48 AM
03/04/10 02:48 AM
Posts: 18 texas
adolph_09
texas
Thanks for the info so right now it's lookin like stock what if I wanted to upgrade to 1.6 rockers would that be a bad decsion would I be able to keep stock springs with the higher lift??
[Re: MoparforLife]
#629885
03/04/10 09:13 AM
03/04/10 09:13 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
stock springs might coil bind with the .474 lift alone....
I'd use comp #901's with stock retainers and locks.
the #901's will be borderline with 1.6 rockers (makes your .474" lift cam .506").
could also look at hughes #1110 springs. should work with stock retainers, and they have enough lift capacity to handle 1.6 rockers.
[Re: adolph_09]
#629887
03/04/10 10:43 AM
03/04/10 10:43 AM
RapidRobert
borrow/rent a valve spring compressor (looks like a giant C clamp) or if the heads are already on then use an on eng valve spring compressor (it has a shaft that replaces a rocker shaft then a lever that slides on it & you pull it toward you to compress each retainer/spring) and use shop air w your compression tester hose or 2-3 feet of 1/4" nylon white rope fed into the cyl to keep the valve from dropping as you R&R each spring/retainer.
[Re: adolph_09]
#629889
03/04/10 11:22 AM
03/04/10 11:22 AM
RapidRobert
I'm assuming comp 901's are a single w maybe the dampener strip inside (which (a single) eliminates any step issues on the head surface and on the underside of the retainer). If the OD is correct and there is no coil bind issues then yes just R&R
[Re: RapidRobert]
#629890
03/04/10 12:32 PM
03/04/10 12:32 PM
patrick
Grand Haven, MI
both springs I mentioned are single w/damper and ~1.45" OD, which should drop on. the comps are ~90lbs seat pressure at a ~1.66 IH and like a 1.12" coil bind height with a rate in the 350 lb/in, the hughes are ~135lb seat pressure at a 1.66" IH with a 1.04" coil bind height, and a 345lb/in rate
the comps are $65-70 thru summit, the hughes ones are $90-95 from their website.
[Re: patrick]
#629892
03/04/10 01:03 PM
03/04/10 01:03 PM
Posts: 18 texas
adolph_09
texas
Ohhhh ok so since they match up I should be able to put them on easliy right?? No machining or anything just remove and replace?? And thanks for all the help on this
[Re: adolph_09]
#629893
03/04/10 01:50 PM
03/04/10 01:50 PM
patrick
Grand Haven, MI
yes, I used the 901's on a 360 and a comp XE262. drop on and go. while you're at it, I'd replace the valve seals....
