Please dont ask why just help
#629652
03/03/10 01:35 PM
03/03/10 01:35 PM
Posts: 1,552 Michigan
Kiddart
In the past I have asked alot of questions and this board continues to WOW me with everything and how much you guys know. So here we go: Can someone supply me with the hole patern dimensions or attache a drawing of the A-Body front spring perches? Its a long story I will explaine later. Thanks Scot B.
Thank you Kiddart
Re: Please dont ask why just help
[Re: Kiddart]
#629653
03/03/10 03:07 PM
03/03/10 03:07 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Maybe you could explain a bit more right now. A body front spring ? Like coil over conversion ? I probably couldn't help you even with more information , but with a little less confusion , ya never know. Edited to add.........it's becoming clearer I think. I do have a set of 7/8ths offset perches that have the mounting bolts you could use for a template if this would help. Or I could take some measurements. This won't tell you where to put the holes on the car.........I could probably measure these on an early A for you , but it may be different for other cars.
[Re: tubtar]
#629654
03/03/10 03:20 PM
03/03/10 03:20 PM
Kiddart
I have the holes already in the frame work but I want to fabricate new spring perch's I figured someone would have this info in there pocket on this site. this way I dont have to tear everything appart, I will only have to take it apart once to do the swap and the welding of the axle tube mounts.
The reason for this question is I am tired of paying top dollar for items at Mancini's. every time I look at something there it cost an arm and a leg when I know I can fabricate them for 1/3 the cost. maybe I will make them and sell them online and charge 50 bucks for the whole kit in stead of 230 bucks.
Just seams all the A-Body stuff is outragous in price.
Thank you Kiddart
[Re: abodiesonly1]
#629658
03/03/10 04:50 PM
03/03/10 04:50 PM
Kiddart
Yes Hangers my bad can yo send the dims or pdf the files to me thru PM or at scotnjennifer@comcast.net.I have an idea how to do this real easy, now did you still but the offset shakels for the back??
Thank you Kiddart
[Re: Kiddart]
#629659
03/03/10 04:52 PM
03/03/10 04:52 PM
Kiddart
B1 I will need the axle perches as well, how can I get them from you??
Thank you Kiddart
[Re: Kiddart]
#629660
03/03/10 05:22 PM
03/03/10 05:22 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
for clarity.. we are talking rear leaf springs on an a body. the front mount hardware/spring eye location on the front of the rear springs that mount to the chassis.? if i recall only one of the studs/bolts (4 mounting studs total)is offset so you dont confuse them side to side.. I recall swapping them from side to side and flipping them over..then just drilling a hole in the chassis for that one offset stud.. this effectively raises the mount hole or lowers the rear ride height at the front spring eye mount..a small amount.. ive also seen guys..just drill out the spring eye bolt up or down ..depending on what direction you want to go. this by the way moves the I/C fwiw.. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: Kiddart]
#629661
03/03/10 05:36 PM
03/03/10 05:36 PM
Posts: 438 Great Lakes Region
abodiesonly1
Great Lakes Region
Yes Hangers my bad can yo send the dims or pdf the files to me thru PM or at [Email]scotnjennifer@comcast.net.[/Email]
How far are you wanting to move them in?
I have a set here for the full 3" in to the frame. You can have them if you want em. Also if you do this, you just drill new holes for the rear shackles. Of course, reinforcing that area is necessary.
[Re: Kiddart]
#629663
03/03/10 08:22 PM
03/03/10 08:22 PM
tubtar
St. Paul , Mn.
I did the 7/8ths offset two years ago with a M.P. kit. I just finished going the full 3" and shoving them under the frame rails.....should have done it in the first place. In a '65 , I could run a 265/60 - 15 with a lot of room using the 7/8ths kit. Problem is , that isn't a lot of tire. I could maybe have gotten a 9" slick in there if it was short enough. Now , I don't know for sure , but it will definitely be enough tire. I used sliders for the rear .......this gives me a little lower ride height than shackles. I have the old kit with some busted studs that should be easy enough to fix ......I'd look at a nut and bolt to make install much easier( they are a chore getting them in and worse coming out ) and the offset shackles that I'd part with for the price of a couple cheeseburgers and shipping. The bear of using them is the nut that is welded to the inside of the perch......you need a good sized hole in the frame rail for this and getting the studs and the nut in and seated at the same time requires some persuasion. But if you have a cut off wheel , sawzall , mig welder and truck drivers vocabulary , you could be mini tubbed , 3" relocated leafs and styling in about 40 hours.
[Re: tubtar]
#629664
03/03/10 08:49 PM
03/03/10 08:49 PM
Kiddart
Tubtar, I do have all the above mentioned items and double on the truckers vocabulary I do have the 3 inch location kit just dont know if I will have the time to dedicate to the task. I think 40 hours is a bit much I figured half that, to 10 hour days should do it. is this alot of work or more calculating and layout then labor. my time is free of course.
Thank you Kiddart
[Re: Kiddart]
#629665
03/03/10 09:15 PM
03/03/10 09:15 PM
abodiesonly1
Great Lakes Region
No, the 3" relocation is not a bolt in deal. After reading all this again, Im lost. You stated you have parts. So is it the layout thats the hold up?
[Re: Kiddart]
#629666
03/03/10 09:31 PM
03/03/10 09:31 PM
tubtar
St. Paul , Mn.
I heard 20 hours , but it took me a little longer. The best advice I got was to go with 10 to 14 inch strips when filling the gap. Of course I didn't take it at first. I split the wheel well about 1/2" inside the seam and cut right along the inside of the bottom edge. then made a cardboard template of the front and rear radius and cut right along the frame rail to where I wanted the radii to come in. This made for very little patching.....like 1 piece that was a small triangle. You need to weld along the top edge of the frame rail to restore structural integrity to the rail , then clamp the inner wheel well to the frame and tack it in. I had 2 7/8ths gap over most of it and and 3 1/8th at the bottom of the rear. I welded from underneath , so I did the equivelant of 10,000 ab crunches while doing it......and didn't lose a gram ! I used 20 gauge mild steel and with my toaster set on low , could actually run beads ( Lincoln 170 ) Once I was satisfied that the inner well was where I wanted it , I welded it in full length , then did the filling of the gap. I made wooden wedges to keep the distance roughly where I wanted it as I went and welded in approx. 10 " strips till covered. There is relocating the trunk hinge supports and notching the package tray brace. Then mudding , sanding and squirting , so 20 hours seems optimistic. But it turned out pretty fair I think.....and i got splatter paint to hide what isn't perfect.
[Re: Kiddart]
#629667
03/03/10 09:35 PM
03/03/10 09:35 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Tubtar,
Its a solid day of layout for a first timer, and solid day of welding and getting it put together, maybe a little bit more. but if you have the tools and the patience I would think the effort would be better spent then
[Re: jcc]
#629672
03/05/10 12:50 PM
03/05/10 12:50 PM
Kiddart
JCC; where did you get those?? never seen them that nice. please share
Thank you Kiddart
