Re: 383 Fuel pump pushrod plug removal
[Re: nz383man]
#629431
03/03/10 10:24 AM
03/03/10 10:24 AM
RapidRobert
Put a breaker bar on that allen wrench ![](/ubbthreads/images/graemlins/blush.gif) and shock it (like you are doing) rather than a gradual pull
[Re: nz383man]
#629434
03/03/10 03:31 PM
03/03/10 03:31 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
KROIL KROIL KROIL...Soak,tap with hammer, repeat. Kroil is unbelieveably better than W-D 40 or ANY others on the market.
If you like drag racing, support your local track.
[Re: CHAPPER]
#629435
03/04/10 04:58 AM
03/04/10 04:58 AM
Posts: 520 New Zealand
nz383man
New Zealand
Plug came out after soaking overnight and some more ![](/ubbthreads/images/graemlins/hammer.gif) Can't believe how much pushrod is worn ![](/ubbthreads/images/graemlins/eeek.gif) Both ends were worn hollow, .018" deep on the cam end & .022" on the pump end. There was major wear on the cam end leaving an effective pushrod length of only 2.874" which is .368" shorter than the MP P529569 pushrod ( 3.242") I measured the travel of the cam lobe & it measures within 2% of a new Comp cam I have to compare it with so I'm not replacing the cam at this stage, just the pushrod. Cheers for your ideas. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Kern Dog]
#629437
03/05/10 06:14 PM
03/05/10 06:14 PM
nz383man
New Zealand
Yep, I hear what you are saying ![](/ubbthreads/images/graemlins/frown.gif) I have lost a lot of metal off the ends of my fuel pump pushrod over a period of time & as an engineer I do understand that there will be other damage caused by the "missimg" metal. The engine is a low compression 383 that has been together & thrashed for quite a few years & although I change the oil & filter very often & drain the oil into a spotlessly clean drain tray so I can look for signs trouble, I had no idea so much metal was going in my oil. ![](/ubbthreads/images/graemlins/rant.gif) Looks like it's time to dust off another block & built a better engine for when this one fails.
