Need advise for a gear ratio for my combo
#629067
03/02/10 05:45 PM
03/02/10 05:45 PM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
Okay heres the deal.My Dart is running 7.20's @94 in the 1/8 and 11.40's @113in the 1/4 ,best 60' is 1.60.Im considering just turning it into an 1/8 mile car cuz thats whats in my area and raced 90% of the time.Heres my specs. Motor:Very mild 10 to 1 408 with a .480 lift hyd cam.It is running completely out of cam at 5700 or so and i shift at 5800. Trans: Powerglide ,with a manual valve body ,trans brake ,and im able to stall it to about 3600 on the trans brake or about 2500 on the footbrake.I think it has a 1.76 low gear in it. Rearend:8 3/4 , 4.10 gears ,35 spline axles with a spool,and im running 26x8.5x15 slicks on it. The car weighs 2795 or about 3015 with me in it. With the current 4.10's its killing it off the line with the high 1st gear in the glide ,and im crossing the finish line at 94 mph at about 4800 (way before its redline of the cam at 5700).In the 1/4 its another problem im running out of gear before i get to the end (hence the sorry mph of 113),so a gear change is in order either way.I cam thinking that a 4.56 should get me about maxed out at 5900 or so in the 1/8 and mulitply the torque alot better off the line .The slicks seem to be able to hold the power now ,even with me using the brake .My 60 foots get better by about .05 with the brake versus footbraking ,but its killing it trying to overcome the gears the way the are with the PG.Im thinking that a 4.56 versus the 4.10 in my combo ,may get me a few tenths in the 1/8 and a better 60'.I know a 3spd auto would be the best answer ,but im sticking with the Glide ,so i am just gunna try and make the best of it .What do think ???
Re: Need advise for a gear ratio for my combo
[Re: The Shocker]
#629068
03/02/10 08:35 PM
03/02/10 08:35 PM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
Sorry but i'm not understanding the whole picture . Maybe why you haven't got any responsed yet .
Transbrake is a valvebody and your launch is decided on launch chip . Racers that go with a P/G are trying to take the low end out the cars launch .
I'm surprised you can't get 6000 or better out of Motor even with hydraulic cam but maybe not enough for a 408 for sure. more gear would help . good luck . DR
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
[Re: The Shocker]
#629069
03/02/10 08:55 PM
03/02/10 08:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think your stall is way too low for the torque range and like it was said the revs seem low, check the springs..... JMO
[Re: 10 o to go]
#629070
03/02/10 09:32 PM
03/02/10 09:32 PM
The Shocker
Sherman Texas
Sorry if i wasnt clear .What i mean is the motor will rev past 6000 ,but it quits pulling as hard after about 5700 .the guy that originally built this 408 told me that he had the springs matched for this cam and that it was only deigned to make power up to 5500.Thats why i dont go much past that point .I plan to upgrade the cam soon ,but i was affraid that if i didnt change the gears first ,that it would make it even more of a dog off the line .Do you think that 4.56 would be a good choice for what im trying to do ,or another ratio ? Please bare with me as im new to automatic racing and Mopars.I have always had 4spd cars in the past ...
[Re: 65signet]
#629074
03/02/10 10:03 PM
03/02/10 10:03 PM
The Shocker
Sherman Texas
Put in a 904 with a low first gear set and call it good
I agree that would be the best choice ,then i could have the best of both worlds .The only problem is that getting a built 904 would cost lots more than a gear and cam swap.New convertor ,driveshaft ,trans ,shifter ,etc,etc.The PG is strong and built right ,plus the best part is its already in the car and paid for.This motor and trans was originally built for and used in a 10.0 altered ,and i figure thats why it was set up this way with the cam and PG trans.Im just trying to make the most of what i have ,and gain a little more is all ,getting the most bang for my buck .I figured that a gear swap and more cam would be the cheapest help .I just am unsure which ratio would get it where it wants to go..
[Re: The Shocker]
#629075
03/03/10 09:14 AM
03/03/10 09:14 AM
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
Now we know why the 408 has a P/G . Put more gear in would be the cheapest . More convertor as Mr p said . Changing cam might run into V/p issues . If you are ready to run this year just go get it done. Don
new 9.96 131.82
6.23 108
1.30 60 foot
[Re: The Shocker]
#629077
03/03/10 12:49 PM
03/03/10 12:49 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
As long as you stay with the glide, it will be soft on the bottom. A good combo change would be a solid lifter cam to change the rpm capability's, allowing more rpm in the lights combined with a steeper rear gear. Might even consider a converter change, to match a new cam, but that might not fit into what you want to spend? The head flow and intake system will have a lot to do with how much more rpm you can get out of it. But you should be able to go at least 6200 rpm in the lights with a flat tappet cam and what you have.
