cooling problems #62886
05/24/08 05:42 PM
05/24/08 05:42 PM
Anonymous OP
Anonymous OP
69 roadrunner, everything brand new including recored 054 radiator, 16lb cap, 180 stat, belts, hoses, mopar performance clutch fan, shroud, etc. The car runs past midway on the gauge and pukes everytime I shut it off. It heats up on the gauge within less than a minute after starting it for the first time. I initially thought my lean condition had something to do with it but I have sorted that out.
My thoughts are defective stat? shop screwed up something when they recored the radiator? cap? maybe something to do with the engine build?
HELP! I am running out of patience with this thing.
Re: cooling problems #62887
05/24/08 05:48 PM
05/24/08 05:48 PM
South Carolina
440_6_BBL Offline
440_6_BBL  Offline
South Carolina
Check your timing. Keep total below 35 degrees if posible. Check for vacumn leak around carb and intake. Change stat to a 160 degree. Try it again.
Re: cooling problems [Re: 440_6_BBL] #62888
05/24/08 06:12 PM
05/24/08 06:12 PM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
Check your lower radiator hose and make sure that it has not collapsed.
-Don
Re: cooling problems [Re: 440_6_BBL] #62889
05/24/08 06:32 PM
05/24/08 06:32 PM
Anonymous OP
Anonymous OP
timing is 34 total, can the antifreeze to water ratio affect anything??
Re: cooling problems #62890
05/24/08 06:48 PM
05/24/08 06:48 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
A 50/50 mix is all that's needed.
Air bubble trapped in the cooling system? I don't know how you would cure that short of draining everything and refilling it.
Re: cooling problems [Re: dm69charger] #62891
05/24/08 06:48 PM
05/24/08 06:48 PM
Anonymous OP
Anonymous OP
looks like trans fluid in the coolant, its all red. what could they have done wrong when they recored this radiator to let this happen??
Re: cooling problems #62892
05/24/08 06:51 PM
05/24/08 06:51 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Sounds stupid but hows your catch can?
Do you have one?
If you do not have one, you are only suppose to fill the radiator just until it covers the core otherwise it will always spit out the water that has expanded.
your only problem maybe that you overfilled the radiator.
Otherwise I would remove the thermostat to make sure there is nothing blocking it. Maybe put a lower temp stat to replace it. Get a thermo heat gun ($40?) from harbor freight and check the actual temp the car is running.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: cooling problems [Re: HealthServices] #62893
05/24/08 06:53 PM
05/24/08 06:53 PM
Anonymous OP
Anonymous OP
no catch can just the overflow hose as original.
Re: cooling problems #62894
05/24/08 06:53 PM
05/24/08 06:53 PM
So Cal
So Cal
That's bad if you got red fluid. But if it is tranny fluid I would suspect it would be foamy and pink? Is it all floated to the top of the radiator?
oh maybe you have Redline water wetter in there!
Water wetter is pink or red (high concentration) to some people and it would be transparent.
I think also some of the newer coolants are reddish now too.
Re: cooling problems #62895
05/24/08 06:54 PM
05/24/08 06:54 PM
So Cal
So Cal
And the level of the coolant when cold?
Re: cooling problems [Re: HealthServices] #62896
05/24/08 07:11 PM
05/24/08 07:11 PM
Anonymous OP
Anonymous OP
coolant level doesnt really change hot or cold, its at the top always. no pink foam and no antifreeze in the trans. I did add a clear water pump anti corrosion additive by zerex but like i said it was clear.
Re: cooling problems #62897
05/24/08 07:12 PM
05/24/08 07:12 PM
Anonymous OP
Anonymous OP
this is definitely trans fluid by the smell of it.
Re: cooling problems [Re: HealthServices] #62898
05/24/08 07:19 PM
05/24/08 07:19 PM
Anonymous OP
Anonymous OP
yes its floating at the top you can stick your finger in there and stir it around an d see good antifreeze.
Re: cooling problems #62899
05/24/08 07:31 PM
05/24/08 07:31 PM
So Cal
So Cal
Take the radiator out to the shop who did it. They should be able to fix it. Tell them about your over heating problem too. Don't drive the car until the leak is fixed. Hopefully it is only on way and you are not getting coolant in your trans.
Pull your tranny dip stick make sure it is not foamy pink in there like a milkshake. Water can damage the clutches really fast
Re: cooling problems #62900
05/24/08 07:36 PM
05/24/08 07:36 PM
So Cal
So Cal
The level should be lower if you do not have a catch can. When you get your radiator fixed fill it at least an inch lower and see if it still spits out. Its hard to go by the gauge when you do not have numbers to reference it to. Especially on a 39 year car.
Re: cooling problems [Re: HealthServices] #62901
05/24/08 07:47 PM
05/24/08 07:47 PM
Anonymous OP
Anonymous OP
trans fluid looks fine but I have $1000 in this trans, is it possible to have it leak one way? I dont want to take any chances, everything on this car is brand new.
Re: cooling problems #62902
05/24/08 07:48 PM
05/24/08 07:48 PM
Anonymous OP
Anonymous OP
Re: cooling problems #62903
05/24/08 07:48 PM
05/24/08 07:48 PM
Anonymous OP
Anonymous OP
Re: cooling problems #62904
05/24/08 08:02 PM
05/24/08 08:02 PM
So Cal
So Cal
If the hole is very small yes it is possible for it to be one way. Trans presure is larger than coolant pressure. But coolant presure is larger than tranny presure when the car is off. So hopefully the leak is a pin hole and can only go one way. Note that your coolant pressure maybe higher because of this leak.
Just being safe I would drain and refill the tranny.
I don't know if you will be able to fully remove the remainder of the oil out of your cooling system though
Re: cooling problems #62905
05/24/08 08:04 PM
05/24/08 08:04 PM
So Cal
So Cal
That looks like tranny fluid and the level is too high.
