Re: cooling problems [Re: HealthServices] #62906
05/24/08 08:11 PM
05/24/08 08:11 PM
Anonymous OP
Anonymous OP
if trans fluid keeps pumping into the rad then that explains why the level never drops?
what exactly could have caused this and why would it make it run hot??
Re: cooling problems #62907
05/24/08 08:15 PM
05/24/08 08:15 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Maybe depending on the amount of oil in the radiator.
Your radiator has a tank for the trans fluid to flow thru. This is to help warm the trans when cold and cool the trans fluid when it gets to operating temp. Sometimes there is a leak in the tank that causes contamination.
I would fix this first and see what your cooling situation is like afterwards
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: cooling problems #62908
05/24/08 08:17 PM
05/24/08 08:17 PM
So Cal
So Cal
It is possible that the tranny fluid in the coolant is preventing the coolant from cooling properly but it could be another problem too.
Re: cooling problems [Re: HealthServices] #62909
05/25/08 01:28 AM
05/25/08 01:28 AM
with the factory trans cooler in the bottom of the rad leaking fluid into the cooling system I would 1st have the radiator shop make good on that & on the overheating my guess is either inadequate radiator, timing retarded or head gasket leaking into the coolant. Good Luck & share with us what it ends up being.
Re: cooling problems [Re: RapidRobert] #62910
05/25/08 02:19 AM
05/25/08 02:19 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I would drain the trans just to be safe.
Re: cooling problems [Re: Joshs68] #62911
05/25/08 07:22 AM
05/25/08 07:22 AM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
And make the shop that screwed up the radiator pay for the fluid/filter.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: cooling problems [Re: gamagoat6x6] #62912
05/25/08 10:43 AM
05/25/08 10:43 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
While you have the radiator out for repair pull the thermostat out and place in a pot with water. Heat the water to see if the thermostat is opening. Preferably place a thermometer in the water to see what temp it opens at. Also, drill a 1/8" hole on the flat surface next to the thermostat valve. This allows easier filling and air bubbles to pass thru from the block to the radiator. I do this with all my thermostats.
Ron
Re: cooling problems [Re: Ronnman] #62913
05/25/08 11:09 AM
05/25/08 11:09 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
When you get it all together, leave the t-stat out and add a couple cupfulls of simple green or something close and water to the rad and run for 5 min and flush, do this several times, you may still have trace amounts of oil in your coolant though.
Re: cooling problems [Re: ademon] #62914
05/25/08 06:34 PM
05/25/08 06:34 PM
Anonymous OP
Anonymous OP
thanks for all the suggestions. I'm going to take the radiator back to him tuesday, I'll post my findings.
Re: cooling problems #62915
05/27/08 09:41 AM
05/27/08 09:41 AM
Anonymous OP
Anonymous OP
radiator shop tells me that my cooler must have a hole in it and that it would have had nothing to do with him recoring the radiator, I think hes full of it since before I took it to him it never had any trans fluid in it and the car doesnt even have 10 miles on everything.
I will be taking him the radiator in the morning and I'll see if he tries to charge me to make it right, he says he will have to pressure it up. I have also talked to another shop about flushing the trans and that will cost $140.
Re: cooling problems #62916
05/27/08 10:53 AM
05/27/08 10:53 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'd ask the radiator shop why they didn't "PRESSURE IT UP" before giving it to you. BS they screwed up should be their dime
Re: cooling problems #62917
05/28/08 12:19 AM
05/28/08 12:19 AM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Just for info, I think a quality shop would have caught the leak as a routine matter. I had my '72 radiator recored four years ago. I took it in because the filler neck was cracked at the rim. Shop owner does the radiators himself and lets his employees do the Air con work. He showed me where the trans cooler tube running through the lower tank was cracked and leaking. I never had any issues with the trans level going down or the cooling sys level going up, but I took the car to a shop and had the trans fluid replaced as a precaution. Recored, replaced filler neck and trans cooler tube. Works good four years later, 230,000 miles now.
Re: cooling problems [Re: DZJim] #62918
05/29/08 10:08 AM
05/29/08 10:08 AM
Anonymous OP
Anonymous OP
went down this morning to check it out and the trans cooler tube has a hole in it that appears to be from corrosion. Its on the bottom side so it wouldnt have been from him recoring it although I feel he should have caught this when he built it. I could have had a nice aluminum radiator in it for what I have in this thing.
Re: cooling problems #62919
06/02/08 05:31 PM
06/02/08 05:31 PM
Anonymous OP
Anonymous OP
Bob at glen-ray radiators hooked me up with a new bottom tank and 15" cooler assy, nice guy to deal with.
