Need main and rod bearings...Where to order? #62768
05/24/08 01:30 PM
05/24/08 01:30 PM
NJ
z1bigtom Offline OP
z1bigtom  Offline OP
NJ
Need to order my bearings now.....What type and where should i order..?
Just get standard Clevite 77..?
Spend a little more and get better?
for a 383
.010/.010
78 D200 Clubcab, 400, 727, Dana 60 welded...Droped 3" front..Rear soon to come
Re: Need main and rod bearings...Where to order? [Re: z1bigtom] #62769
05/24/08 03:43 PM
05/24/08 03:43 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clevite is as good as they come.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Need main and rod bearings...Where to order? [Re: MoparforLife] #62770
05/24/08 03:48 PM
05/24/08 03:48 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I get mine from the machine shop that does my block and crank.
Re: Need main and rod bearings...Where to order? [Re: z1bigtom] #62771
05/25/08 12:20 PM
05/25/08 12:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
clevite or FM , i just got some from summit , the clevite mains are cheaper than the federals by 10 bucks or so .
Re: Need main and rod bearings...Where to order? [Re: JohnRR] #62772
05/25/08 12:28 PM
05/25/08 12:28 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
You can also get them from Summit Racing, Mancini Racing, and PAW. Can't go wrong with the Clevite's though...
Re: Need main and rod bearings...Where to order? [Re: CR8CRSHR] #62773
05/25/08 01:07 PM
05/25/08 01:07 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
440 source also sells them.
Re: Need main and rod bearings...Where to order? [Re: dirtybee] #62774
05/25/08 01:09 PM
05/25/08 01:09 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Bought mine from mancini.
Re: Need main and rod bearings...Where to order? [Re: DaytonaTurbo] #62775
05/25/08 01:23 PM
05/25/08 01:23 PM
NJ
z1bigtom Offline OP
z1bigtom  Offline OP
NJ
Put my list together lastnight...Some stuff from Summit most from 440Source...
Man this adds up!!!! LOL
