Wheel Gurus, What do these wheels fit?? #62745
05/24/08 01:09 PM
05/24/08 01:09 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
I need a technical wheel guy. Anybody know what these wheels will fit?
The specs are
Enkei 15" with center caps. 8.5" wide rims with 5 lug 4.75 bolt pattern and 3.5" backspacing.
I got a great deal on tires and rims, but I only bought them for the tires. The seller said they were on a 77 Vette?
Is that correct and will they fit any chevy???
thanks!
Finoke
Re: Wheel Gurus, What do these wheels fit?? [Re: Finoke] #62746
05/24/08 01:12 PM
05/24/08 01:12 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
The 4.75 bolt circle is correct for older GM cars and some light trucks and the backspacing is about right for generic rear wheel drive applications.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Wheel Gurus, What do these wheels fit?? [Re: Finoke] #62747
05/24/08 01:14 PM
05/24/08 01:14 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
5 on 4.75 pattern will fit most GM cars except the biggest ones that use a 5 x 5.00 pattern. On a '77 Vette I would think those wheels stuck out of the wheel openings.
Re: Wheel Gurus, What do these wheels fit?? [Re: topside] #62748
05/24/08 01:55 PM
05/24/08 01:55 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Thanks Guys, that gives me enough to go on.
Tom Finoke
Re: Wheel Gurus, What do these wheels fit?? [Re: Finoke] #62749
05/24/08 01:59 PM
05/24/08 01:59 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
I've got one more for ya, 2 wheels, ARE no center caps. 15" by 8" wide. 5 lug by 5 1/2" bolt pattern with 3 3/4" backspacing...
thanks again,
Finoke
Re: Wheel Gurus, What do these wheels fit?? [Re: Finoke] #62750
05/25/08 09:41 AM
05/25/08 09:41 AM
moparx Offline
moparx  Offline
5 lug 5 1/2" bc is for ford pickup, 4x4s including scout, jeep, international, dodge, early ford to 1948 [excluding the "wide 5 pattern] and was used on a few import pickups also, i believe.
Re: Wheel Gurus, What do these wheels fit?? [Re: moparx] #62751
05/25/08 10:30 AM
05/25/08 10:30 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The 5.5 inch will also fit 80 and up 4x4 1/2 ton dodgetrucks-ramcharger too. Oh, don't forget, Geo Tracker.
Re: Wheel Gurus, What do these wheels fit?? [Re: buildanother] #62752
05/25/08 01:01 PM
05/25/08 01:01 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
are you measuring the width from the bead or the edges of the rim?
Re: Wheel Gurus, What do these wheels fit?? [Re: buildanother] #62753
05/26/08 09:47 AM
05/26/08 09:47 AM
moparx Offline
moparx  Offline
how could i forget that gem ?....
Re: Wheel Gurus, What do these wheels fit?? [Re: west] #62754
05/26/08 02:45 PM
05/26/08 02:45 PM
Horsham, Pa.
Finoke Offline OP
Finoke  Offline OP
Horsham, Pa.
Measured from the width of the bead.
Thanks to All! They gives me enough to go on, so I can pop them on Craigs list.
thanks
Tom Finoke
