Re: easiest way to swap an EFI Magnum into E body?
[Re: DJVCuda]
#626718
07/22/10 11:46 AM
07/22/10 11:46 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
i though you would consider it for the street rod... it's a setup designed for them.... not he blower car.
got a tank from rockvalley, they put in an EFI pump in there.
i may consider it for the rod,,if the pricing was afforable,,just got off the phone with mega squirt,,making the factory magnum efi work it too costly,,, so i may just rebuild a 318 i have here,,,been thinking if i find a set of 360 type heads, have pistons made to be at 9.5 compression with the bigger valve heads,,bigger chambers and a stock 340 cam,,may be the ticket to having and affordable dependable motor,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: Fury Fan]
#626720
07/22/10 12:05 PM
07/22/10 12:05 PM
fstfish66
levittown pa
Depending on the price of the Magnum engine you're looking at, throwing a carb and intake on that engine may be a simpler/cheaper/faster alternative to rebuilding an on-hand engine. You could sell some of the EFI stuff, too.
The Magnum engines have LOTS of benefits that may entice you - better heads for swirl and quench, roller cam, thinner piston rings for less friction, etc. More hp and better MPG do come hand-in-hand with a 5.2/5.9 Magnum (versus an LA).
yes im considering making an offer on the motor ,,and searching a carb intake,,dual plane ??? to have all the other bennys of the magnum,,,roller cam,,serpintine belt etc,,seems the easiet way to run the factory efi is a hot wire conversion ,,,searching the intake now
[Re: 2010Charlie]
#2470825
03/23/18 04:15 AM
03/23/18 04:15 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I would like to get a hold of you about your harnesses tried to PM you but it said it was full. Not sure what his status is - that post is 8 years old, and looking at his profile, that member hasn't posted in here in 3 years. BTW, welcome to Moparts . . .
Free advice and worth every penny... Factory trained Slinky rewinder.........
