9 inch or 8 inch thats the ? #626373
02/28/10 12:21 AM
02/28/10 12:21 AM
arizona
leavitt4 Offline OP
leavitt4  Offline OP
arizona
ok im pretty sure this is a 8 inch rear end but just wanna confirm it the code on the rear end tag is WCZ-L is there a site out there where i could look this code up to confirm it or does anyone know off the top of there heads any help would be appritiated thanks jason
Re: 9 inch or 8 inch thats the ? [Re: leavitt4] #626374
02/28/10 01:39 AM
02/28/10 01:39 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Ford you mean ?
If so, easy way to tell is look at it...the couple of bottom mounting nuts (for the center pumkin) if you could put a long extension on them to remove them, it's an 8"....if the pinion support area overhangs (on the bottom) a couple of them, it's a 9"
You can kind of see here on mine what I am saying. This is a Strange housing, but same basic idea..
Re: 9 inch or 8 inch thats the ? [Re: leavitt4] #626375
02/28/10 02:15 PM
02/28/10 02:15 PM
arizona
leavitt4 Offline OP
leavitt4  Offline OP
arizona
ok cool ty yea mines deffinatly a 8 inch then now weather to run it or keep searching for a 9 inch
Re: 9 inch or 8 inch thats the ? [Re: leavitt4] #626376
02/28/10 03:21 PM
02/28/10 03:21 PM
Iowa,US
4bbl Offline
4bbl  Offline
Iowa,US
I guess I would considor the weight of the vehicle versus horsepower and go from there.
4bbl If you can't hear it coming what's the point.......
Re: 9 inch or 8 inch thats the ? [Re: 4bbl] #626377
03/10/10 09:12 PM
03/10/10 09:12 PM
arizona
leavitt4 Offline OP
leavitt4  Offline OP
arizona
ok did some research and found out its neither a 9 inch or a 8 inch its a 7 3/4 so im leaning twards scraping it and continue looking for a 9 inch housing
