What's the torqure value on 8 3/4 OEM caps...?? #626329
02/27/10 11:19 PM
02/27/10 11:19 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Subject says it all. THANKS!!
Re: What's the torqure value on 8 3/4 OEM caps...?? [Re: cudadoug] #626330
02/27/10 11:23 PM
02/27/10 11:23 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
90 ft-lbs
Re: What's the torqure value on 8 3/4 OEM caps...?? [Re: 446acuda] #626331
02/28/10 01:16 AM
02/28/10 01:16 AM
cudadoug Offline OP
cudadoug  Offline OP
90 ft-lbs
Thank you!
Re: What's the torqure value on 8 3/4 OEM caps...?? [Re: cudadoug] #626332
02/28/10 01:16 AM
02/28/10 01:16 AM
Cab_Burge Online work
Cab_Burge  Online Work
1970 Plymouth service manual calls for 90 lbs on the 8 3/4 and 70 to 90 lbs on the 9 3/4 Dana 60 Same size bolts
