Rod Bolt Stretch #625667
02/27/10 11:38 AM
02/27/10 11:38 AM
Mo.
supercomp Offline OP
Mo.
Can someone tell me what the arp rod bolt stretch is for a Manley H-Beam 6.765 Mopar rod with
ARP-2000 bolts is. I had it saved somewhere but can't find it. Can't find it on the internet either. Thanks
Re: Rod Bolt Stretch [Re: supercomp] #625668
02/27/10 12:10 PM
02/27/10 12:10 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Re: Rod Bolt Stretch [Re: supercomp] #625669
02/27/10 12:24 PM
02/27/10 12:24 PM
Cab_Burge Online work
Cab_Burge  Online Work
Manley does NOT want you to use rod bolt stretch lengths on there rods, torque only using a good racig oil was the last instructions I saw Which size and type of ARP rod bolt are you using? I think I still have the instructions for the the Manley H beam rods in my 527 stroker, it has the Mopar rod bearings sizes in them. Let me know if I can help with anything off of the instructions
Re: Rod Bolt Stretch [Re: Cab_Burge] #625670
02/27/10 12:37 PM
02/27/10 12:37 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I was resently told by a tech at ARP you need to use the exact torque spec/procedure as the rod manufacturer specifies for the rod in question. Do NOT use a generic spec.
In other words you want to use the same torque on those bolts that the manufacturer had on them when the rods were machined.
SRT DEMON ONE SEAT
Re: Rod Bolt Stretch [Re: Cab_Burge] #625671
02/27/10 12:44 PM
02/27/10 12:44 PM
Mo.
Mo.
I would appreciate the help.
Re: Rod Bolt Stretch [Re: supercomp] #625672
02/27/10 04:06 PM
02/27/10 04:06 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
the best way to use the strech method is to measure the length of the bolt, torque the bolt to Manley's spec's and then remeasure the length and record all the info for future use and to determine if the bolt has been stretched beyond the mfg spec in a free state, for replacement purpose, call Manley.
Re: Rod Bolt Stretch [Re: supercomp] #625673
02/27/10 05:13 PM
02/27/10 05:13 PM
I'm glad I went out and check the actual instruction sheet instead of trying to quote from memory The set of rods I have the instruction sheet for are Manley part # 14082-8PC, thses are forged H beam rods with Mopar rod journal size with .990 wrist pin size and there 6.9657 long according to the label on the box. The instruction sheet is dated 2/18/00, the bolt part # on the sheet is 42239 (I'm assuming this is a Manley part number, not the ARP part number ) Bolt material is 8740, it shows the bolt diameter as having 1.800 U.H.L.(under head length probally, that is what they measure using a old set of Craftsman dial calipers). The instructions say to thoroughly clean the parting line area and threads prior to assembly and the fasteners MUST be submerged in 30 WT.oil or equivalent. Do not use moly or engine lube (this is in bold type ) Bolt stretch value should be checked against torque prior to installation. DO NOT OVER TORQUE!(this is on the sheet that way ) The torque value is 90 Ft. LBs with oil, the bolt stretch value is .0059 minimum to .0063 max, again with 30 WT. moror oil. They want .002 to .003 rod bearing to crankshaft clearances and .020 to .035 rod side clearances per pair. they recommend .0008 to .0015 wrist pin clearances. IHTH. I wish I knew how to scan the sheet(it is old and worn ) and post it on here also, but I don't Let me know if there is anything else on the sheet you want me to quote
Re: Rod Bolt Stretch [Re: Cab_Burge] #625674
02/27/10 06:01 PM
02/27/10 06:01 PM
Mo.
Mo.
Thanks for the help. Much appreciated.
