Page 9 of 16 1 2 7 8 9 10 11 15 16
Re: Are 413 Engines really all that special? [Re: BigBlockMopar] #62529
12/12/09 07:08 PM
12/12/09 07:08 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Re: Are 413 Engines really all that special? [Re: BigBlockMopar] #62530
12/12/09 08:08 PM
12/12/09 08:08 PM
scratchnfotraction Offline
either way,with either on top
they call me the junk man
I have a lot of junk
but I got some fast junk
I will admit,I put a 440 in the 85 truck cause I got it for 300$ with 75,000 miles on the clock from a MH
it should do sumtin..I just shaved 60 foot of MH off it and stuck it in a striped 85 short bed with 3.91 sg got 800$ in the whole thing all "used parts"
you can get some fast junk mixing stock parts around IMHO
let me get a 413,i will be sure to have fun with it
Re: Are 413 Engines really all that special? [Re: Reggie] #62531
12/12/09 08:57 PM
12/12/09 08:57 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've heard Andy is secretly working on a new book.
Here's a sneak preview...
Just ribbin' ya Andy!
Re: Are 413 Engines really all that special? [Re: HYPER8oSoNic] #62532
12/12/09 09:00 PM
12/12/09 09:00 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
I agree with you as far as popularity quote.
Because it is popular, does not make it the
"world class motor", you want it to be. Chrysler
always gave the enthusiasts choices, different
strokes for different folks; no pun intended.
Their engines ALL run! Because you have a
high-dollar 440 that is run on both street and
strip, DOES NOT make me a lesser racer (read
person) cause I have a "warmed-over" 383 with
iron heads that runs 12.50's all day. If the guys
are so sure that a single type of motor is so
superior, then enroll in class type racing! Prove
your motors worth. Most of us rather "run against
the clock" and help others to improve their combos to run better. There is no room for
the "ultimate motor", unless you are bucking
for sponsorship to build them. It is called being
a student and scholar in the world of automotive
technology.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Are 413 Engines really all that special? [Re: Pacnorthcuda] #62533
12/12/09 10:44 PM
12/12/09 10:44 PM
This is supposed to about engines, not people, stay OT please. Some might interpet your reply as a baiting comment, I will not quote it to allow an edit, should you reconsider
And the OP asks "Are 413 Engines really all that special?" In my opinion, no. There is nothing about them that puts them in any sort of special class, like max-wedge, hemis, 6-pack engines etc.
As far as mopar engines go, they are pretty "average" by most metrics.
Thats not to say they aren't a great engine--most mopar engines are!
But "really all that special" ??? No
oh im sorry.. did I steps on your guys TOES by questioning what a GURU said about 413's? I suggest you re-read the Gurus statements too.. they went a tad beyond the "YES or NO" answer too.
if your bothered to read my first post on this subject.. here it is again for your amusment
"make that 3 Devotees (i think you and AndyF should try building one FIRST before you guys throw out blanket statements). can't build a 413 to go eh? lol. a pontiac 455 has a bore and stroke of 4.15" × 4.21". nobody can deney that in the day it was a wickedly strong engine. 413 has a 4.18" x 3.75" bore and stroke .030" larger bore then the pontiac 455. valve sizes are roughly the same too. I wager that cube for cube.. ie: stroke a 413 to a 4" stroke making 439cid (yes i know custom pistons blah, blah, blah). the way smaller bore 413 will make more horsepower & torque then the larger bore 440. thats a guarantee"
Re: Are 413 Engines really all that special? #62534
12/12/09 11:09 PM
12/12/09 11:09 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
And throw the same 4" crank in the 440 and watch the real show.....
You guys really crack me up....
Re: Are 413 Engines really all that special? [Re: Reggie] #62535
12/12/09 11:17 PM
12/12/09 11:17 PM
and the self proclaimed gurus crack me up as well.
prove me wrong. if you think you get the same hosrepower from a 4.32" x 3.75" vs 4.18" x 4.00" bore and stroke 440 cid engine your sadly mistaken my friend.
Re: Are 413 Engines really all that special? #62536
12/12/09 11:29 PM
12/12/09 11:29 PM
USA
dodge_nut Offline
dodge_nut  Offline
USA
you are comparing apples to oranges.. make it apples to apples and you are on! no replacement for displacement.
but really, this isnt about which block is better as both had their place in history. it is nothing about stroking one or the other, its about whether or not a 413 block is special, and well.. the answer is no. it is NO WHERE near as special as any other wedge block. they ALL can be strok'd, piston'd, head'd, or cam'd to perform.
so really you are beating a dead horse trying to get others to believe what you want to believe, which is.. well.. i have no idea what it is.
Re: Are 413 Engines really all that special? [Re: HYPER8oSoNic] #62537
12/12/09 11:39 PM
12/12/09 11:39 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Think ill stay away from 413 engines all together...This topic is like a tennis match..Back and forth and im getting dizzy
Re: Are 413 Engines really all that special? [Re: SPWC] #62538
12/12/09 11:43 PM
12/12/09 11:43 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Gee where are the 426 guys???
Re: Are 413 Engines really all that special? [Re: Reggie] #62539
12/12/09 11:49 PM
12/12/09 11:49 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
I think a 225 slant 6 C body will outrun a 440 A body any day of the week. Only because the /6 is lighter.
Re: Are 413 Engines really all that special? [Re: Reggie] #62540
12/12/09 11:50 PM
12/12/09 11:50 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Ya know Reg', there is such a thing as having
TOO MUCH LOW END. I guess you like watching
tailights from the "tree".
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Are 413 Engines really all that special? [Re: Reggie] #62541
12/12/09 11:57 PM
12/12/09 11:57 PM
Desert Tracker
Desert Tracker
Sitting back, having cold ones, laughing at the
nonsense you are throwing in the forum.
Re: Are 413 Engines really all that special? #62542
12/13/09 12:06 AM
12/13/09 12:06 AM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Dont forget it will be custom built crank too...
Re: Are 413 Engines really all that special? [Re: dodge_nut] #62543
12/13/09 12:10 AM
12/13/09 12:10 AM
its which is.. well.. i have no idea what it is.
it is these STUPID claims that a 4.18" bore will not make horsepower.. that there "pathetic" "useless" etc. Hyper, bigblock, know the real story on these engines. the rest of you guys are being herded like sheep.
and Jack, the crank was a hypothetical example.
but again.. prove it wrong.. if you can..
Re: Are 413 Engines really all that special? #62544
12/13/09 12:14 AM
12/13/09 12:14 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You aren't going to get the same kind of horse power out of a 413 that you can a 440 doing the same things to both equally.
Re: Are 413 Engines really all that special? [Re: JonC] #62545
12/13/09 12:15 AM
12/13/09 12:15 AM
Desert Tracker
Desert Tracker
Jon, only if if built to HYPERPACK specs or
better. The 440 A Body should not slip the tires
at the start. If the A body hooks good, the 225 will be toast on the big end. If the A Body
burns tires past the tree and the 225 cuts a
good light, things could be interesting. Weight
is a big factor as well as traction.
Re: Are 413 Engines really all that special? [Re: stumpy] #62546
12/13/09 12:26 AM
12/13/09 12:26 AM
Desert Tracker
Desert Tracker
You may be right Stumpy. But the horsepower
difference between the two
is not as great, as everyone quotes it to be.
Where the 413 loses in top end horsepower,it
makes it up, big, in midrange torque.
Re: Are 413 Engines really all that special? #62547
12/13/09 12:26 AM
12/13/09 12:26 AM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Well, if it's hypothetical, then you cant prove it right or wrong.
Re: Are 413 Engines really all that special? [Re: BigBlockMopar] #62548
12/13/09 12:42 AM
12/13/09 12:42 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
He sent me an advance copy. I hate to play spoiler but I will.
1st chapter outlines finding a 440 to build, or finding the best deal on a megablock.
2nd chapter details removing the 413 from your car.
I want my fair share
