Re: Factory Kickdown Linkage and Performer RPM
[Re: 67Satty]
#624629
02/26/10 12:58 AM
02/26/10 12:58 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
With a little fab-work, you can make it happen. Here's mine on a low-deck. I wanted a stock look (and I'm sorta cheap, so I tend to work with what I've got). This started as a stock 2-bbl setup. I extended the height of the stock throttle cable bracket, and bent the top kick-down rod to fit the extra ht. Then had to add threaded rod onto the end of the original rod to make it reach. Seems to work perfectly.
[Re: 67Satty]
#624630
02/26/10 10:16 AM
02/26/10 10:16 AM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
Will factory kickdown linkage work with a Performer RPM intake? The car is a '67 Satellite 440/727. I don't have the stock kickdown linkage around to try so that's why I ask so I know if I will have to order some kind of cable kickdown setup. Thanks!
There is no such animal as kick down linkage.Throttle press linkage yes,kick down linkage,no.
[Re: I go fast]
#624631
02/26/10 11:04 AM
02/26/10 11:04 AM
Of course, if you disconnect the throttle pressure linkage, the transmission will no longer "kick down."
Gensrud's solution is the same one I've done several times. Modify the stock pieces to get the lengths and angles right; helps if you have a welder.
[Re: stumpy]
#624634
02/26/10 05:29 PM
02/26/10 05:29 PM
I go fast
Wilmington,NC
"Of course, if you disconnect the throttle pressure linkage, the transmission will no longer "kick down."
Right, but it will fry becasuse of low pressure.
And it won't down shift either!
[Re: 62maxwgn]
#624637
02/26/10 09:12 PM
02/26/10 09:12 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Firewall clearance dictates whether or not the one-piece rod will work.
[Re: I go fast]
#624639
02/26/10 09:54 PM
02/26/10 09:54 PM
If you come to a stop it will . . . .
[Re: 67Satty]
#624641
02/27/10 01:16 AM
02/27/10 01:16 AM
John_Kunkel
Rio Linda, CA
Ever see the term "kickdown linkage" in a FSM?
[Re: Dougsmopars]
#624645
02/27/10 01:12 PM
02/27/10 01:12 PM
Posts: 387 n/w, PA
demonH1B
n/w, PA
Because we still have people that think the "linkage" isn't necessary if you manually downshift (kickdown). There were transmissions built with "kickdown linkage" and other shifts were controlled by a vacuum modulator, but not by Chrysler.
[Re: demonH1B]
#624647
02/27/10 01:41 PM
02/27/10 01:41 PM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
Does the throttle pressure linkage also operate the kickdown function? Are there kickdown valves, kickdown servos, and is the front band also called the kickdown band in the FSM? The answer to these questions is Yes. If the throttle pressure rod did not have anything to do with the kickdown function then maybe then it would be a misnomer. In short, this is nothing more than formal semantics. There is nothing lexically or conceptually wrong with calling the throttle pressure linkage/rod the kickdown rod. The important thing is that we all know what you mean. My
