Page 3 of 3 1 2 3
Re: Header evac tubes- how do they compare to vac pumps [Re: Mr.Yuck] #624352
03/03/10 02:12 PM
03/03/10 02:12 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I was wondering about the angle of the tube.90 degrees and down in the pipe or flush with the pipe?
Re: Header evac tubes- how do they compare to vac pumps [Re: Todd] #624353
03/03/10 02:25 PM
03/03/10 02:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
click the link.
http://static.summitracing.com/global/images/instructions/mor-25900.pdf
Re: Header evac tubes- how do they compare to vac pumps [Re: Mr.Yuck] #624354
03/03/10 02:33 PM
03/03/10 02:33 PM
Ohio
Todd Offline
Todd  Offline
Ohio
that is the one way ive seen it installed and the other way looks the same but the tube is rotated around 180 degrees so the angled end faces the exit of the pipe. I would like to know what is the best way.
Re: Header evac tubes- how do they compare to vac pumps [Re: Todd] #624355
03/03/10 02:40 PM
03/03/10 02:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
what is the best position for the tubes in the headers? Ive seen them installed a couple of differnt ways.
I prefer the flat of the tube to be parallel with
the exit of the collector
Re: Header evac tubes- how do they compare to vac pumps [Re: Todd] #624356
03/03/10 02:42 PM
03/03/10 02:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not sure I understand you, the tube is placed at a 45* towards the exhaust. I think as long as you have the tube towards the rear of the car you are ok. Not everybody has room right on top of the header like that.
Re: Header evac tubes- how do they compare to vac pumps [Re: MR_P_BODY] #624357
03/03/10 02:58 PM
03/03/10 02:58 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I think thats the way im going to install them. Makes much more sense than the angle paralell to the pipe and not the collector.
Re: Header evac tubes- how do they compare to vac pumps? [Re: tjmarcus1] #624358
03/03/10 04:37 PM
03/03/10 04:37 PM
Upland, California
Spode Offline
Spode  Offline
Upland, California
Some tech answers for guys like me who didnt know thing about this subject
web page
Re: Header evac tubes- how do they compare to vac pumps? [Re: Spode] #624359
03/03/10 05:59 PM
03/03/10 05:59 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
web page
you're sooo right forgive us stuuupid folks.
Re: Header evac tubes- how do they compare to vac pumps? [Re: Mr.Yuck] #624360
03/04/10 12:31 AM
03/04/10 12:31 AM
Upland, California
Spode Offline
Spode  Offline
Upland, California
web page
anytime
Re: Header evac tubes- how do they compare to vac pumps? [Re: Spode] #624361
03/04/10 11:31 AM
03/04/10 11:31 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Last winter we messed with our moroso header ev system because we had a problem with the check valves rusting and gettin stuck, I cut the weld holding the tube in the collector < open headers> and played with moving the tube around while running the engine @ 2500 rpm to find the spot with max vacuum, I also booted the check valves and found some more vac with out them, With the morosso system installed as per their instructions we made around 2 to 2.5 inches, I posted last year about anyone not running the check valves cause I was not sure if this was gona be a problem and for the most part had not found anyone blowing up on a back fire. Raff posted a pic of a curved e vac tube that was square with the collector tube so I tried it out and found some more vac that way, I also found that the breather cap tube was too close to the baffle in the valve cover and found some more there, So by the end of messin around we more than doubled the vac @ 2500 rpm, I have seen as much as 5.5 inches and have not blown up yet. As far as power goes I cant tell any difference but no more oil leaks
Re: Header evac tubes- how do they compare to vac pumps? [Re: emarine01] #624362
03/11/10 01:18 PM
03/11/10 01:18 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
This question will probably sound really dumb, but how much vacuum would a stock PVC setup and the stock breather to air cleaner tube put on the crancase in comparison with an evac setup on the headers?
This is the land of the free because of the brave
Re: Header evac tubes- how do they compare to vac pumps? [Re: rbstroker] #624363
03/11/10 02:27 PM
03/11/10 02:27 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
It depends on the cam being used. But at full throttle, there should be >3" hg.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Header evac tubes- how do they compare to vac pumps [Re: Todd] #624364
03/11/10 04:05 PM
03/11/10 04:05 PM
Az
Crizila Offline
Crizila  Offline
Az
This is what I am trying right now. 45 degree entrance about 1/2" in. End is parallel to the pipe and 1/2 of it is capped and the trailing 1/2 of the pipe is cut flush with the pipe.
Fastest 300
Re: Header evac tubes- how do they compare to vac pumps [Re: Crizila] #624365
03/11/10 05:45 PM
03/11/10 05:45 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Have you ever syphoned anything with a blow gun and compressed air? What way is it most effective? My guess would be to have the angled cut of the evac tube paralell to the collector. I would turn the tube 180 degrees and leave the 45 degree entrance angle and see what happens.
Re: Header evac tubes- how do they compare to vac pumps [Re: Todd] #624366
03/11/10 05:51 PM
03/11/10 05:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you get yours in?
Re: Header evac tubes- how do they compare to vac pumps [Re: MR_P_BODY] #624367
03/11/10 06:03 PM
03/11/10 06:03 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Not Yet. But im definatly going to take a picture and post it.
Page 3 of 3 1 2 3
