Bronze distributor gear in 360 Magnum? #623489
02/25/10 02:12 AM
02/25/10 02:12 AM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
I have a late model 360 magnum out of a 98 ram that I'm swapping a new cam into. The cam I'm using is a billet steel core and I was wondering if I need to use a bronze distributor gear with this or if the stock magnum gear will work fine.
Thanks.
Re: Bronze distributor gear in 360 Magnum? [Re: chache876] #623490
02/25/10 02:28 AM
02/25/10 02:28 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If it doesn't have the 2pc core you will need the bronze gear.
