U bolts,shock plates #622987
02/24/10 05:32 PM
02/24/10 05:32 PM
Canada
Dons Dart Offline OP
Canada
Ok my 7 1/4 will soon be history.I need to get new u bolts anyone done this swap and what lenagh did ya use 7,8,9, inch I have 5 leafs now and plan on haveing one more added.69 dart 8 3/4 is what I am working on Thanks.
Re: U bolts,shock plates [Re: Dons Dart] #622988
02/24/10 05:40 PM
02/24/10 05:40 PM
scratchnfotraction Offline
any car shockplate from a larger axle will work
the u-bolts are 3" wide and how long you need
on mine in the 68 Dart I used stock plates and u-bolts from a 74 Dart with 8 1/4 axle
measure your u-bolt from top of axle tube to end of bolt
or center of u-bolt to ends of bolt
Re: U bolts,shock plates [Re: scratchnfotraction] #622989
02/24/10 06:19 PM
02/24/10 06:19 PM
Canada
Canada
cant measure yet houseing is still on my bench.Maybe someone could measure there A body and have an answer.Hey CanAl up to measuring your 69.
Re: U bolts,shock plates [Re: Dons Dart] #622990
02/25/10 09:23 AM
02/25/10 09:23 AM
the 74 dart u-bolts and spring plates I used on my 68 Dart and the 85 truck
are 3"x7" stock
I have used longer ones from lowering kits and cut them off when torqued down also
Re: U bolts,shock plates [Re: scratchnfotraction] #622991
02/25/10 09:54 AM
02/25/10 09:54 AM
Canada
Canada
Ok kind of figured I could cut them down.Thanks.
