Re: Welding axle tube ? [Re: theclutcher] #622914
02/25/10 11:37 AM
02/25/10 11:37 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
7018 is one of the BEST rods out there, and its great for this application too. BUT 7018 is the number one most misused rods out there. If it isnt kept in a moisture free oven after a while it gets pretty bad, hard to start an arc, and will get porrosity pretty easily. I love that rod, but I also made a nice rod warmer out of an old fridge. It has a heat lamp in it is all, and the door seals up nice.
This would be the best for the application for sure.
Kasey
Re: Welding axle tube ? [Re: Moparnut426] #622915
02/25/10 12:14 PM
02/25/10 12:14 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If it can be stick welded it can be Mig welded,unless someone knows a little secret that I don't know.What ever process,the important factor in any weld is the "heat effected zone".To rate this factor of heat transfer,stick welding,mig then tig being the lesser.With the constant development of mig process and technology there is not much that can't be welded by an adverage skilled person with a mig using the proper material and gases.
Re: Welding axle tube ? [Re: B G Racing] #622916
02/25/10 12:50 PM
02/25/10 12:50 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Main advantage of the stick electrode in this circumstance is the cleanliness issue of the joint to be welded imo.
the flux agents with 7018 help to minimize porosity that has the potential to occur from the dirt/oil residue that exists between the tube and the casting.
agree, the advancements with mig, ie gas mixes, metal core mixtures etc are greatly improving weld quality results.
Re: Welding axle tube ? [Re: theclutcher] #622917
02/25/10 01:17 PM
02/25/10 01:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Valid point We usually work with new or clean housings and clean any residue in the preheating and cleaning process before welding.If oil and other contaminates are present even with stick welding it will effect the weld.Usually using a spray cleaner and heat will cause the contaminates to migrate from the area to be welded.
Re: Welding axle tube ? [Re: onyxba] #622918
02/25/10 01:47 PM
02/25/10 01:47 PM
vidor texas
4nhemi Offline
4nhemi  Offline
vidor texas
Hello Brian how's the cuda coming along? As for the axel tube to housing preheat and weld with an econo-cast99 call coastal welding and they'll help you out.
Charlie
