Positive Battery Cable Routing Bracket E/B body #62162
05/23/08 02:45 PM
05/23/08 02:45 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Can someone post a pic to show how and where it mounts on the frame rail? Thanks.
Re: Positive Battery Cable Routing Bracket E/B body [Re: rayztoy] #62163
05/24/08 01:16 PM
05/24/08 01:16 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Anyone?
Re: Positive Battery Cable Routing Bracket E/B body [Re: rayztoy] #62164
05/24/08 03:50 PM
05/24/08 03:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I had a pic, but can't find it.
It mounts on top of the framerail just about the same location of the brake lines and valves. I think just rearward of such
Re: Positive Battery Cable Routing Bracket E/B body [Re: gtx6970] #62165
05/24/08 08:24 PM
05/24/08 08:24 PM
MoreParts Offline
MoreParts  Offline
Here's a pic with my crappy cell camera. Hope this helps.
Re: Positive Battery Cable Routing Bracket E/B body [Re: MoreParts] #62166
05/24/08 08:43 PM
05/24/08 08:43 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
You can see alittle bit of the bracket...
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Positive Battery Cable Routing Bracket E/B body [Re: 70sixpkrt] #62167
05/24/08 09:03 PM
05/24/08 09:03 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Does this help? Got this off the web a while back, not sure about the part numbers...
68 Hemi Road Runner
Re: Positive Battery Cable Routing Bracket E/B body [Re: 68jim] #62168
05/24/08 09:33 PM
05/24/08 09:33 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
They all help alot, thank you to all!!!
