F 440 HP Damper & Rods
#62087
05/23/08 11:41 AM
05/23/08 11:41 AM
I am trying to build an F440 HP 4BBL (assembled Trenton MI plant 8/12/69) as close to stock as I can. I have a conflict between sources as to when in the '70 model year Mother Mopar went to externally balanced 440 4BBL's with the six pack rods, balancer and flywheel/converter vs internal balanced.
If you have a 1970 F440 HP 4BBL (U code or E86 Option) with the original unmolested engine let me know the assembly date of your engine and if you have the six pack rods/balancer (eccentric weight)or a neutral balanced balancer.
I walked around the Mopar show at Englishtown this weekend and saw a mixed bag, some internal balanced, some external. The pattern looks like early F440HP's are internal and they didn't go external until the October '69 engine builds.
Re: F 440 HP Damper & Rods
#62089
05/23/08 04:33 PM
05/23/08 04:33 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The factory parts manual shows the heavy rod in all '70-'71 440 HP with no date limits.
[Re: John_Kunkel]
#62090
05/23/08 05:44 PM
05/23/08 05:44 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
![](/ubbthreads/images/graemlins/iagree.gif) FWIW my December 1969 6-Pack motor had the "six pack" rods and damper (which of course were used in all HP motors so the 6-Pack moniker is misleading) I'd LOVE if someone could prove that some 1970 Cars got HP motors with LY's 'cause then I could use the lighter rods and still be PS legal. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#62091
05/24/08 07:43 AM
05/24/08 07:43 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
are you going to certify the car ? ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: JohnRR]
#62092
05/24/08 01:23 PM
05/24/08 01:23 PM
I am not sure what "certify" means. I intend on taking it to Carlisle and the Nationals next year and have it judged.
[Re: Barnabas_Kriss]
#62093
05/24/08 01:37 PM
05/24/08 01:37 PM
My E86 Challenger is an automatic. It came with a blue 383 under the hood and the original 440 long gone. I found the right date 440 HP Block, bought reconditioned six pack rods and the correct weighted torque converter (rebuilt). I am going to go with SRP 30 over pistons.
I figured it would be easier to balance this non matching assembly with a virgin crank rather than than one that has already been cut or filled so I bought a new Eagle forged crank. I am thinking to balance the collection of new parts and be able to run it on an engine dyno I need to use a six pack flywheel (can't spin the torque converter without the trans) to maintain the correct weight offset from the torque converter. Does this sound reasonable?
[Re: craigsmytcudas]
#62097
05/26/08 12:37 PM
05/26/08 12:37 PM
DPelletier
you guys do know if your k member has a skid plate you will have a 6 qt pan that was part of the heavy rod motors package .mopar did not build on the by gosh by golly program that means no plate no rods
Nope. The original K-frame in my original motor, V-code car had no skid plate.
1974 'Cuda
