NOS Mobil 1 SJ-rated oil --> additives settling? #620799
02/22/10 12:44 PM
02/22/10 12:44 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I've got enough unopened quarts 10-year old Mobil 1 15w50 "red cap" SJ oil on hand for two oil changes. I'm thinking the only issue w/ using it is if the additive package has fallen out of suspension. Mobil says their oils have a shelf life of five years, but this stuff is twice that old.
Anyone have experience w/ Mobil 1 experiencing additive settlement after long periods of storage? If it has, would it be as simple as shaking up the bottles to re-mix it before using it? FWIW, this would be used in a 600 HP street / strip engine.
Re: NOS Mobil 1 SJ-rated oil --> additives settling? [Re: BradH] #620800
02/22/10 02:23 PM
02/22/10 02:23 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
That oil is probably better than anything Mobil 1 sold after hurricane Katrina. Your oil has additives for flat tappet cams which the newer M1 15w50 no longer has in the same abundance. The newer oil is fairly wimpy (though it will still work well with a roller camshaft)...M1 actually says it's still safe for a flat tappet cam, yet it meets SM specs at the same time...I'm not buying it.
Run it and don't worry about it.
If it makes you feel better, shake well before using.
I'm undecided if my next oil change should be with
SAE 30 Delo 400 SG, or 20w50 GTX SE.
I have no doubt either one will work just fine.
If you're concerned about running it, send it all to me for proper disposal....
Re: NOS Mobil 1 SJ-rated oil --> additives settling? [Re: BradH] #620801
02/22/10 03:20 PM
02/22/10 03:20 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
There are many factors that affect the shelf life of stored lubricants. A general guideline is five years, but again that's dependent on many factors.
For more information: Lubricant Shelf Life and Proper Storage pdf. - link
Re: NOS Mobil 1 SJ-rated oil --> additives settling? [Re: BradH] #620802
02/22/10 10:26 PM
02/22/10 10:26 PM
BradH Offline OP
BradH  Offline OP
FWIW, I'm going to open one of them and pour it into a clear container to see if I can notice any indications of the additives falling out of suspension, etc.
I've also got an equal amount of Redline 10w40 in the same condition, but have already found one example of old Redline showing definite signs of this problem. So... 12 qts of $8+/qt oil are going into the local oil recycler's barrel.
Re: NOS Mobil 1 SJ-rated oil --> additives settling? [Re: BradH] #620803
02/22/10 11:24 PM
02/22/10 11:24 PM
BradH Offline OP
BradH  Offline OP
Just opened one quart and poured it carefully into a clear container. Everything looked clear and consistent in color. Then I looked into the bottom of the original bottle w/ a bright light and detected "something" of high viscosity (wasn't "pouring" even though the container was upside down, etc.) coating the very bottom lightly. I scraped a little bit of it w/ the end of a screwdriver just to see how "gluey" it was and it came up w/o any problem.
So, I poured the oil back into the bottle and shook it up for a minute or so, then repeated the pour-and-inspect process. Other than the air bubbles from my shaking it up, no visible difference in clarity, etc., AND the "stuff" I'd seen on the bottom of the bottle had mixed back into the rest of the oil.
Looks usable to me.
Re: NOS Mobil 1 SJ-rated oil --> additives settling? [Re: BradH] #620804
02/23/10 10:48 AM
02/23/10 10:48 AM
S.E. Michigan
S.E. Michigan
Shake up the Redline also.
It should act the same as the Mobil 1.
Re: NOS Mobil 1 SJ-rated oil --> additives settling? [Re: ZIPPY] #620805
02/23/10 12:11 PM
02/23/10 12:11 PM
BradH Offline OP
BradH  Offline OP
I'll do the same procedure w/ the Redline and see how that turns out. I won't go into details here, but I'm expecting the Redline to have significantly more indications of additive fall-out that won't re-suspend (easily?) by simple shaking.
Re: NOS Mobil 1 SJ-rated oil --> additives settling? [Re: BradH] #620806
02/23/10 12:44 PM
02/23/10 12:44 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Wisk it briskly until it holds the peaks
Re: NOS Mobil 1 SJ-rated oil --> additives settling? [Re: BradH] #620807
02/23/10 12:53 PM
02/23/10 12:53 PM
S.E. Michigan
S.E. Michigan
If it doesn't come back quick with shaking, tighten the caps securely and leave all the bottles upside down for a week. Then shake them, and take a look at what you've got. It should be fine....but if you don't like the looks of it, send it this way..I'll gladly run it in my garden tractor
