Re: Hooker Header Clearance problem on B-Body anyone else
[Re: KY Charger]
#620673
02/22/10 10:05 AM
02/22/10 10:05 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I had the same problem years ago with my 383-powered '68. I fixed it with a hammer.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#620674
02/22/10 11:41 AM
02/22/10 11:41 AM
Posts: 579 Wattsburg, Pa
Dr V
Wattsburg, Pa
Same problem here on the gtx. Heat it and tap it lightly.
69 1/2 A12 BEE 4 spd 1968 Charger 383 1970 Roadrunner 440+6 Survivor 2019 Redeye 2005 FORD GT Red/White 2017 Viper ACR Extreme Red/White 1979 Branco Red/Red 2018 Porsche GT3 Miami 1971 440+6 Cuda 4 speed V2 2020 Sebring Orange Vette 1979 Chevy Boogie Hippie Van
[Re: Kern Dog]
#620678
02/24/10 02:12 PM
02/24/10 02:12 PM
Posts: 5,270 Missouri
MY340
Missouri
My Hooker headers fit fine on my A-body 70 Duster 360 with no clearance problems. Raise the torsion bars alittle and welded a skid plate for insurance on the driver side tubes. For like $169 they seem to be still a good product for the money. Ask the 4spd guys about their fitment issues with TTI's.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: MY340]
#620679
02/24/10 02:38 PM
02/24/10 02:38 PM
Posts: 583 San Antonio, TX
CurYellowBird
San Antonio, TX
I got a buddy who bought those headers for his 69' Charger RT/SE and had a helluva time getting the fitment right. Little heat and tap it with a hammer is how he fixed it.
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
[Re: CurYellowBird]
#620680
02/24/10 03:02 PM
02/24/10 03:02 PM
Posts: 3,054 USA
b54406barrel
USA
I think I paid about $300 w/shipping for my coated hookers so I didn't feel too bad when I had to tweak a little. Heck, I've been doing that to everything on cars for 45 years! That's the fun part. Sometimes. According to tti, their headers wouldn't work on my 6bbl car anyway because it's a column shift auto. No problem with the hookers.
[Re: KY Charger]
#620681
02/24/10 03:02 PM
02/24/10 03:02 PM
Posts: 17,843 S.E. Michigan
ZIPPY
S.E. Michigan
My 5903 headers fit both the 440(stock heads) and the 400 block(e heads) in my manual steering B body very well. The only issue I ran into was with the angled plugs on the e heads on two cylinders, couldn't quite get a socket on the plugs without two tiny dings maybe 3/8 x 3/8 for socket clearance.
With the 400 block I later switched to Hooker 5209 which is larger primary/secondary, but was even easier to install and also fit and worked great.
Some guys have all the luck, right?
later, I decided my motor mounts were getting old, and replaced both sides with NOS TRW, made in USA insulators. Doing that created a slight torsion bar interferance problem on one side (I forget which side, but I think it was the left side). There went the luck....
Being that the old motor mounts were a perfect fit + the new mounts caused a slight issue, what I think I'll do now is take some moroso solid mounts and modify them to be the same dimensions as the squashed old mounts.
Rich H.
Esse Quam Videri
[Re: rapom]
#620685
02/26/10 12:14 PM
02/26/10 12:14 PM
Posts: 3,054 USA
b54406barrel
USA
Do these headers work with power steering and column shift?
Yep. I converted my rr to power steering same time I put the hooker's on. It's very close to the ps box but doesn't hit. I put a little dimple in just to make sure but after it was all together, I didn't really need it. Didn't do anything to the column shift linkage, no issue. Only issue I did have was the driver side collector flange rattling against the torsion bar occasionally so I tweaked it towards center.
[Re: lokalik]
#620686
02/26/10 02:52 PM
02/26/10 02:52 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
, after much fighting with hooker...... . after much fighting with hooker
Sorry, but sounds like part of a good drinking story.
As far as topic, the problem I found to be worst was when I put new LCA bushings in, they moved the T-bars in and created interferance. Wasn't a problem with the worn out ones!
[Re: RemCharger]
#620687
02/26/10 03:07 PM
02/26/10 03:07 PM
ZIPPY
S.E. Michigan
Between that and the motor mount issue I ran across, is there a pattern developing here. Maybe they developed those headers using a car with 100,000 miles on it or something
[Re: rapom]
#620689
03/03/10 08:04 AM
03/03/10 08:04 AM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
My 70 Charger RT is a 4speed with powersteering. They fit like they were grown there!!!
