Re: shaker base plate seal
[Re: Day2Runner]
#620317
02/21/10 10:19 PM
02/21/10 10:19 PM
Posts: 1,022 Green Lane, PA
sawdust
Green Lane, PA
does the seal have a staple at the glue joint toward the bottom ??
Cannot say I have ever seen that but maybe Scott Smith can verify. The originals I have do not show any evidence of a staple, though anything could be possible.
[Re: screamindriver]
#620320
02/21/10 10:40 PM
02/21/10 10:40 PM
sawdust
Green Lane, PA
It's been a while since I've restored the adapter ring but I somewhat remember some{I did'nt put any back on}staples...Old age and too much info in my head.. ...And yes that door seal does'nt even have the texture the original did...But I used it anyway... ...Another wonderful repop item...Although I did'nt slop the yellow glue all over the parts like the factory did...
Sounds like you need to upgrade your hard drive and maybe RAM? Maybe a couple beers would help with the sloppy workmanship for gluing?
[Re: sassysixpack1]
#620321
02/21/10 10:45 PM
02/21/10 10:45 PM
sawdust
Green Lane, PA
I will post some more underside pictures of an NOS seal installed on an original Shaker ring for reference. There should be more than a 1/4 inch on the underside to glue though, maybe 1/2 to 5/8. For now this is what I have from the topside.
[Re: sassysixpack1]
#620324
02/22/10 12:37 PM
02/22/10 12:37 PM
Posts: 1,912 Anchorage, Alaska
Iceman01
Challenged
Challenged
Anchorage, Alaska
So extending this question to the next step in the process, what is the best way to do the actual glueing? I need to do mine soon and from the test fitting it appears I'll need clamps. Is that correct?
Until total honesty is on the table, we're not even talking about reality...
