Re: *Dana 60* how long ......
[Re: qwkmopardan]
#618082
02/19/10 05:22 PM
02/19/10 05:22 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
I have gotten as few as 440 and over 2000. The set that went over 2000 runs was a factory Dana 4.88 set. Avg is about 1000
What finally broke? Was it the gear? Pinion? Cap? Bearing wore out?
[Re: cl440]
#618088
02/20/10 02:00 PM
02/20/10 02:00 PM
Posts: 603 Central Oregon
Rodney
Central Oregon
Really? Only 2 guys on the whole board running a Dana 60
A for the Saturday crowd.
here are 3 and 4 running Dana's in our GTX and 63 Dodge. we chose to use the Dana for the strength and fitment in our b body cars. The Ford 9 inch was our 2nd choice but for fitment and the loss of horse power due to parasitic friction the dana won out. it will depend on whether a pro gear or standard gear is being used, the way I understand how the softer pro gear is designed to work IE take the shock of a trans brake and higher HP engines. The pro gear {the way I understand them} will need to be set up after X amount of runs since the softer gears do wear at a faster rate than the harder street gears... I've broken both 8 3/4 and Dana's, the ring gear in both cases. IMO it's tough to know how a part will last. weight of car quality of parts, how they initially were set up and broken in ect.
[Re: wheelsup68dart]
#618090
02/20/10 03:08 PM
02/20/10 03:08 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
My car only runs 11's,but the Dana was installed in 1982 and it still has it's original gear set.OEM Dana 5.13 gear,the axle assy.is a Direct Connection part.The new 4,56's I have are also stock OEM Dana parts.No trans brake and I change the fluid every year.
#618091
02/20/10 05:49 PM
02/20/10 05:49 PM
cl440
S.E. Michigan
Chuck, the Dana in my car was run from 1985 to 2007 off the trans brake on the same fluid before it finally had 3 teeth on the ring gear let go. This was a stock gear set too
WOW! 22 years on the same fluid!! LOL I know they don't contaminate the fluid like a street car would but....... of course your car weighs what? 2200# soaking wet?
