Re: Cheap suspension upgrades?
[Re: autoxcuda]
#616509
02/18/10 06:56 AM
02/18/10 06:56 AM
Posts: 29 ohio
m300b
ohio
[Re: migsBIG]
#616511
02/18/10 11:12 AM
02/18/10 11:12 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
I just ordered a set of UCA's at $159 with free shipping over the phone. Tell them you saw it for $159 and they may honor it. I also ordered two sets of 1" t bars because $159 per set is a STEAL. They shipped it all for free too. How in the heck can they do that?
[Re: m300b]
#616515
02/19/10 10:28 PM
02/19/10 10:28 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Are there any sway bar fitment issues when using disc brakes?
If you're asking about our product, no there isn't.
[Re: m300b]
#616516
02/20/10 12:00 AM
02/20/10 12:00 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
If you are running a 66 K-member that has the wide style sway bar you should run the calipers to the rear of your spindle.
You can shorten the sway bar links, but I think it's a cleaner install to just put them in the rear.
[Re: m300b]
#616518
02/20/10 01:31 PM
02/20/10 01:31 PM
autoxcuda
So Cal
I have a 68 k member in the Belvedere convertible. (car was a slant 6). Car is completely stripped (on a rotisserie) and all I have done is welded in frame ties. Car will be a Sunday driver that I want to feel more "modern".
Would it be wise to use the weld-on control arm sway bar brackets from Hotchkis? Looks like a cheap & clean install.
Thanks Guys
Good think you got a 68 K-member with the better thru bolt idler arm. Great idea to put subframe connectors in a convertible.
I think the $30 66-69 Hotchis sway bar adapters are a great deal and make for a install the looks stock unless you're eyeballs are under 2' away from you LCA's under your car.
On a conv. cruiser, I wouldn't go any more that 1" T-bars.
[Re: autoxcuda]
#616519
02/20/10 07:55 PM
02/20/10 07:55 PM
Posts: 29 ohio
m300b
ohio
