Stumped?? #61637
05/22/08 01:31 PM
05/22/08 01:31 PM
Washington
AFDRAGRACER Offline OP
Washington
I've been running 14.50's in my Dart w/3.55's in the rear. I put 4.10's in and saw no change in et. I'm going through the trap at around 5000rpm. I don't get it. That is a pretty decent jump in gearing, should I have seen a change in et &/or top end rpm? I'm at a lost...seems like everything I do to improve performance the car just stays in the 14.50's. Any ideas?
oh ya quick stats with the car:
360 .030, 9.5 to 1 comp, 2500 stall, 750 Edelbrock carb, 280 HL Isky cam
70 Duster, stroked 360
<img src="/ubbthreads/images/graemlins/2231195-dggif.gif" alt="" />
Re: Stumped?? [Re: AFDRAGRACER] #61638
05/22/08 01:34 PM
05/22/08 01:34 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Hows your 60' times? Maybe you spin more with the 4.10.
Re: Stumped?? [Re: AFDRAGRACER] #61639
05/22/08 02:38 PM
05/22/08 02:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
whats the MPH between the 2 runs ?
Re: Stumped?? [Re: bobby66] #61640
05/22/08 03:13 PM
05/22/08 03:13 PM
Washington
Washington
60' times were close to the same but not as consistant as before: 2.13 - 2.19. I didn't feel it spin but the air temp was over 100 so I'm sure the track was good and hot.
Top end speed was the same as before 92-93mph.
I know air temp can slow the car, but I still thought I would see a change. I just feel like I'm missing something? Thanks.
Re: Stumped?? [Re: AFDRAGRACER] #61641
05/22/08 04:49 PM
05/22/08 04:49 PM
my own world
theraif Offline
theraif  Offline
my own world
May want to check your tech
Re: Stumped?? [Re: theraif] #61642
05/22/08 07:28 PM
05/22/08 07:28 PM
God's Country Maryland
GODSCOUNTRY340 Online content
GODSCOUNTRY340  Online Content
I'd check your fuel system to be sure you're getting enough gas to the engine during your run. I've seen fuel delivery problems cause your symptoms. If you have a fuel gauge and it drops below 5 pounds pressure during the run you need to fix it. (3/8" fuel line from the tank, electric pump, regulator, new filter for 3/8" line, float level). Will the engine RPM past 5,000 in first & second? If not you may have a valve spring problem.
