headlights #61570
05/22/08 11:56 AM
05/22/08 11:56 AM
Howell, Michigan
Hemidavey Offline OP
Howell, Michigan
I'm working on a 70 Charger, the headlights don't open so I checked the motor, it works but the relay is bad and the "delay" relay is missing. Are these parts available anywhere? I tried a few parts stores and came up empty.
Re: headlights [Re: Hemidavey] #61571
05/22/08 12:45 PM
05/22/08 12:45 PM
The relay is 2983605, you may have to do an NOS search, or get a used one from a 70 C body Plymouth with hideaways, it is the same.
The only "time delay" I know of is for the ignition lamp (just to light up the key), Available at Chrysler 2889565.
Re: headlights #61572
05/22/08 10:57 PM
05/22/08 10:57 PM
Howell, Michigan
Howell, Michigan
Thanks for the tip. The delay relay is on the 70 Charger wiring diagram, thats the only way I'm aware of it. I'll look at the C body stuff.
