Who Sells Timing Belt Drives? #614807
02/16/10 06:37 PM
02/16/10 06:37 PM
Sweet Home Alabama
MRMOPAR622 Offline OP
Sweet Home Alabama
Does anyone besides Jesel sell the timing belt drives? I know Jesel is the best but at this time I can not afford a Jesel. I was thinking someone a while back was talking about someone who had them a lot cheaper. I need it for a race engine.Thanks
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Who Sells Timing Belt Drives? [Re: MRMOPAR622] #614808
02/16/10 06:51 PM
02/16/10 06:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There is a Aussie made one(forgot the name and I own
one) at least for a BB
Re: Who Sells Timing Belt Drives? [Re: MR_P_BODY] #614809
02/16/10 06:59 PM
02/16/10 06:59 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Australian Muscle Parts. They don't have any replacment parts, though, So, when you need seals, bits and pieces etc, you have to find them at a bearing house, or you're screwed. I have one I would sell for $400, but it needs the cam drive fixed. They do work well, but it takes an act of God to get any replacment parts. Buy a Jessel, they have great stuff.
Re: Who Sells Timing Belt Drives? [Re: MRMOPAR622] #614810
02/16/10 06:59 PM
02/16/10 06:59 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
CHEAPER and a belt-drive can not be used in the same sentence !
IF .. you do not need between-round cam-timing changes ...I would just stick with a good STANDARD timing chain and gears.
Re: Who Sells Timing Belt Drives? [Re: dOc !] #614811
02/16/10 07:10 PM
02/16/10 07:10 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
one place to have the best and hope it doesn't fail
Re: Who Sells Timing Belt Drives? [Re: MRMOPAR622] #614812
02/16/10 07:28 PM
02/16/10 07:28 PM
AndyF Offline
AndyF  Offline
Mancini Racing has belt drives.
Re: Who Sells Timing Belt Drives? [Re: camastomcat] #614813
02/16/10 07:33 PM
02/16/10 07:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does the Jesel belt fit the Aussie unit
Re: Who Sells Timing Belt Drives? [Re: MR_P_BODY] #614814
02/16/10 07:46 PM
02/16/10 07:46 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I dunno but have a couple Jessel belts for oem height cam/block location if anyone has a brand X to compare.
Re: Who Sells Timing Belt Drives? [Re: Rodney] #614815
02/16/10 07:55 PM
02/16/10 07:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a Aussie unit for the standard height cam BUT I'm
not home and wont be for 2 weeks
Re: Who Sells Timing Belt Drives? [Re: MRMOPAR622] #614816
02/16/10 08:11 PM
02/16/10 08:11 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
I just read an article in March 2010 Hot Rod and Jesel just came out with a "affordable" belt drive for $695.uses a 1 piece upper pulley.not tryinf to sell it,I ran a gear drive(Keith Black)
just my
Re: Who Sells Timing Belt Drives? [Re: Hemiruss] #614817
02/16/10 08:39 PM
02/16/10 08:39 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I would be looking at a Milodon Gear drive if I wanted rock steady timing, and bullet proof engineering.
I also agree if you cant afford a new belt drive, then buying a used one, and ordering up $100+ replacement belts will get old fast
I Milodon gear drive will last as long or longer than anything in the engine.
Re: Who Sells Timing Belt Drives? [Re: Bob_Coomer] #614818
02/17/10 05:49 AM
02/17/10 05:49 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
probably the reason for lack of parts might be due to the factory in aussie was in those big fires they had over there just over a year ago? don't know if it was on your tv but we got to see some huge fires towns destroyed. Bendigo i think the place was. i have one of their units and I have a couple of spare parts so i guess i'm lucky. the belt on the Aussie unit is a MITSUBOSHI 640H8M. So i'm guessing thats 640mm so i guess thats around almost 26 inches. how long is the Jesel belt? what exactly is broken on your one comatomcat?
