413 pistons #614415
02/16/10 09:38 AM
02/16/10 09:38 AM
MO
Griffin Offline OP
Griffin  Offline OP
MO
Anyone have a source for forged flat top pistons for my 413? All I can find are either regular cast or cast hypereutectics.
Re: 413 pistons [Re: Griffin] #614416
02/16/10 09:57 AM
02/16/10 09:57 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Give Bob Mazzolini a call, if he don't have what you're looking for he may be able to steer you in the right direction
Re: 413 pistons [Re: Griffin] #614417
02/16/10 05:44 PM
02/16/10 05:44 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
You found some cast and hypers ?
WHERE ?
Re: 413 pistons [Re: dOoC] #614418
02/17/10 03:23 PM
02/17/10 03:23 PM
MO
Griffin Offline OP
Griffin  Offline OP
MO
Summit racing has them...$41-$53 depending on the exact one. They are Federal Mogul's...the cast are flat tops and the hypers are dished
link
Re: 413 pistons [Re: Griffin] #614419
02/17/10 03:26 PM
02/17/10 03:26 PM
MO
Griffin Offline OP
Griffin  Offline OP
MO
Also, JE Pistons will make a custom set for $1050
Re: 413 pistons [Re: Griffin] #614420
02/17/10 03:39 PM
02/17/10 03:39 PM
AndyF Offline
AndyF  Offline
Lots of sources for forged 413 pistons, you just need to be willing to pay for them. Diamond, Wiseco, JE, Ross, etc can all make 413 pistons. It is just a tall 383 piston, or a small diameter 440 piston, either way it is not really a big deal. There isn't anything special a 413, standard valve angles and pin size. Not sure what kind of rings are available in that bore size so that might be an issue. There are a lot of good rings available at 4.250 but that is a lot of material to remove. If you look around you can probably find SB Chevy rings in the 4.210 range.
Forged flat tops will probably run about $700 a set with pins. You just need to know how what to ask for. If it was me I'd start with Diamond Racing and see what they say. You'll need to know what bore size you're shooting for before you'll make much headway though. A 0.030 over 413 is an oddball size and there isn't going to be much more than low speed truck rings avaiable at that size.
