Is a Cam Button necessary? #613826
02/15/10 01:38 AM
02/15/10 01:38 AM
Retired now in Tennessee
Chi_Town_Runner Offline OP
As the title says.
Is it absolutely necessary on a roller cam that is street use only?
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Is a Cam Button necessary? [Re: Chi_Town_Runner] #613827
02/15/10 02:04 AM
02/15/10 02:04 AM
northeast texas
strokin73cuda Offline
northeast texas
Yes, it is all that keeps it from outrunning the car. If your lucky like I was the timing cover will slow it down. On a flat tappet cam the lobes are ground on a slight (lower toward the rear of engine)angle to keep it pushed against the block also is the reason the lifters rotate in the bores. Roller cams are ground perpindicular to the cam centerline. Plus the buttons are very inexpensive
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: Is a Cam Button necessary? [Re: strokin73cuda] #613828
02/15/10 01:25 PM
02/15/10 01:25 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Is a Cam Button necessary? [Re: Chi_Town_Runner] #613829
02/15/10 01:53 PM
02/15/10 01:53 PM
Az
Crizila Offline
Crizila  Offline
Az
As the title says.
Frank
Don't build a BB without one, no matter what kind of cam you plan to run.
Fastest 300
Re: Is a Cam Button necessary? [Re: Chi_Town_Runner] #613830
02/15/10 02:46 PM
02/15/10 02:46 PM
AndyF Offline
AndyF  Offline
You don't need one on a small block. You do on a big block or a Hemi.
Re: Is a Cam Button necessary? [Re: AndyF] #613831
02/15/10 10:40 PM
02/15/10 10:40 PM
Thanks guys.
It's done
Frank
