Hey guys, I've been away from small blocks for so long, I have forgotten the intricasies...
This cuda was a 318, I'm putting in a 80 -81 360 from a truck.
The pass manifold APPEARS to be the same, but I'm swapping the drivers. Not sure if gasket overhang will be an issue.
The drivers side engine mount doesn't line up to the rear boss (bout a 1/2 " back...
I installed a new oil pump and "proper?" car pickup.
The pan I got from the wrecker (360 car?) seems that the rear pan seal is larger than needs to be.. It seems to be the same size as the front? What pan is this?
What dipstick do I need?
Thanks for any help, Rem
